77 Differential
Old Jul 12, 2016 | 12:25 PM
JYD's Avatar
JYD
4th Gear
Default 77 Differential
Blew my differential last weekend. Carrier let loose and took out everything! Has anyone used Ecklers or Corvette Central differential? I have a 77 with a 427.030 Big Block 4speed any suggestions will be greatly appreciated !
Old Jul 12, 2016 | 03:52 PM
bluedawg's Avatar
bluedawg
I would use this as an excuse and have either trackdog or gary Ramadi (I believe this is his name, l82kid is his sone and can direct you)build a beefier rear end, both have rave reviews, I'm sure the corvette central diff is built to stock specs, and will work to stock limitations, but your car ate one already, they might be cheaper until you buy 3 or 4 plus what ever they take out when they go, then they're not that cheap.
Good luck and just my $.02
