Still no low-end
Old Sep 11, 2002 | 06:28 PM
Aaron-74's Avatar
Aaron-74
Default Still no low-end
I hooked up my trans thing to my intake. Set my carb as best as I could and set my initial timing up to 12-14 deg.advance...pulled out of the drive way gunned it, now low end really. What could be ther problem??I heard the XE-262 was GREAT for low-end?? :confused:
Old Sep 11, 2002 | 06:57 PM
Shark Racer's Avatar
Shark Racer
Default Re: Still no low-end (Aaron-74)
Is the carb dialed in? Could have something to do with a poor mixture.
What's the condition of trans?
What torque converter?
-Steve
Old Sep 11, 2002 | 07:00 PM
QuickVet's Avatar
QuickVet
Default Re: Still no low-end (Pacin'California)
mabey the tranny is shot. :confused:
Old Sep 11, 2002 | 07:40 PM
Aaron-74's Avatar
Aaron-74
Default Re: Still no low-end (QuickVet)
The tranny is fine. Stock converter...I don't know if the timing and carb are dialed in correctly....I don't really know ignition.
Old Sep 11, 2002 | 07:43 PM
Aaron-74's Avatar
Aaron-74
How do i tell if it's shot??? It shifts fine and everything..no whine or noise..no clunks
Old Sep 11, 2002 | 08:08 PM
Chris O''s Avatar
Chris O'
I have the same problem. 3.36 diff, TH350, ex 256 cam, ported 882 heads with 2.02/1.6 valves, perf intake port matched, headers, tuned carb/ignition = 226 rwhp.......still can't smoke 'em. Hits 2000rpm and takes off!
I suspect torque conv and am thinking of replacing with a 2400 stall.
:cheers:
Old Sep 11, 2002 | 08:13 PM
Matt Gruber's Avatar
Matt Gruber
try advancing the timing even more. i found my 72 really jumps with an extra 2 degrees. have to listen for the dreaded ping, however.
i assume it has electronic ignition.?
Old Sep 11, 2002 | 08:18 PM
Aaron-74's Avatar
Aaron-74
Default Re: Still no low-end (Chris O')
:cheers:
Yeah, but CompCams said this cam is fine for stock convertors.
Old Sep 11, 2002 | 08:40 PM
dman535's Avatar
dman535
I have always found that small block auto C3's are just not tire torchers out of the hole. Most of the later cars are heavy and with with IRS/Weight distribution they are not apt to getting real loose out of the hole. I am now running a 70or4 with a 3.55 gear, am just now gettin squeal off the line. Car lauches hard, but it won't do a 350 tpi, straight axle iroc camaro blow the tires away routine.
Old Sep 11, 2002 | 08:57 PM
nunus79's Avatar
nunus79
My 2 cents: You've done a lot of mods to increase your upper rpm power. So, it shouldn't be too much of a surprise that your low end lags a little. Take it out to the track, you might be pleasantly surprised!! That kind of powerband can be very beneficial coming off the line. Might change your whole outlook on things! Good Luck!
Old Sep 11, 2002 | 09:25 PM
Aaron-74's Avatar
Aaron-74
Default Re: Still no low-end (nunus79)
I was talking to my buddy Jeff (no-radio) and he said that since I'm still running open headers A. The carb isn't going to tune right. and B. Exhaust adds backpressure, which will help add a little more torque. He said I really shouldn't worry about it too much until I get full exhaust, tune it and then worry.
Old Sep 12, 2002 | 12:42 AM
Twin_Turbo's Avatar
Twin_Turbo
Yeah, open headers will kill your low end if you don't adjust the carb for it.
Old Sep 12, 2002 | 12:44 AM
Aaron-74's Avatar
Aaron-74
Default Re: Still no low-end (Twinnie)
I think that's my main problem too. After the motor got warmed up it ran TOTALLY different..
Old Sep 12, 2002 | 08:45 AM
DeenHylton's Avatar
DeenHylton
Aaron, is your carb a DP or vacuum secondary? If its a DP you'll make more low-end torque and run quicker if you replace it with a vacuum secondary carb that's set up properly. Leave the DP's to the stick shift cars or automatics with higher stall converters (3,500 RPM and up). Deen
Old Sep 12, 2002 | 12:25 PM
DavidOrr's Avatar
DavidOrr
I posed this same question a while back. I'm running the xe262, 1.52 magnum rollers, performer intake, 670 holley street avenger, hooker comp headers, true dual's, 3.55 rear, th350 trans.
Some of the answers I received were somewhat lame, however a few were valid. I sent an email to Comp Cams to question them. Bottom line, my engine starts to produce around 2500-3000. I leave rubber from 1st to 2nd, and 2nd to 3rd - but can't manage anything from a stop.
Comp cams - said this is what I should expect with this cam. I'm somewhat disappointed, I was wanting more low end. But I do have to admit, if I'm rolling at 25 - throw her down into first and my 25-100 is fairly impressive.
David
Old Sep 12, 2002 | 12:28 PM
Fevre's Avatar
Fevre
Default Re: Still no low-end (DavidOrr)
Get a 650 dp and you will have a little umph off the line. Just be ready to fill up more since you won't be able to keep your foot of the floor. :)
[Modified by Fevre, 10:34 AM 9/12/2002]
Old Sep 12, 2002 | 04:39 PM
Aaron-74's Avatar
Aaron-74
Default Re: Still no low-end (Fevre)
It's not a double pumper. It's a 650 vac.sec electric choke carb.
I guess after I get my exhaust I'll see..maybe a 2000 stall is in order soon.
Old Sep 12, 2002 | 04:43 PM
Fevre's Avatar
Fevre
I have a 600 vac sec and when I put on my 750 sp I felt a diff off the line even when keeping off the sec. I think a 650dp might be better and hope to stumble across one. What's one more carb? :)
To Still no low-end
