Bad News...I think
Old Sep 12, 2002 | 01:19 PM
Mystery Machine's Avatar
Mystery Machine
Default Bad News...I think
The vette is at the shop 'cause I heard a knocking sound and oil pressure was VERY low at idle. Talked to the mechanic today and he says he is "checking the rod and bearings" and he "found alot of gray
residue in the oil pan" he is researching that too. I'm supposed to get in touch with him tomorrow. Should I be expecing seriously bad news? Does anyone know what this might be? Thanks! :confused:
Old Sep 12, 2002 | 04:09 PM
Mystery Machine
Default Re: Bad News...I think (Mystery Machine)
Anyone? :confused: :confused: :confused:
Old Sep 12, 2002 | 04:13 PM
Fevre's Avatar
Fevre
Sounds like rod knock. Bearing shavings in the oil pan. Been there done that. :(
Old Sep 12, 2002 | 04:15 PM
Mystery Machine
Default Re: Bad News...I think (Fevre)
Thanks. Does this mean a rebuild is in order?
Old Sep 12, 2002 | 04:20 PM
Fevre's Avatar
Fevre
Most likely rod resizing and crank grinding. If it does need rebuild now is the time to do any mods you might have planned or wanted to do. I highly recommend a 383 kit since you can get them for around $800 balanced and it will add power and torque. If you have a matching numbers L-82 then maybe just get it rebuilt, but a matching l-48 might is a tough call. Non matching is a def in my book.
Old Sep 12, 2002 | 04:36 PM
Mystery Machine
It's an L-82...numbers matching but I'm really not all that concerned with originality. I'm not terribly mechanical so I think I'd be hiring the work out. Where would I find the 383 kit and is it a huge job? I imagine it is...after all the motor needs to come out!
Old Sep 12, 2002 | 05:06 PM
Fevre's Avatar
Fevre
The L-82 is a great starting point and adding a diff cam won't affect the cars value much if at all so you can have a pretty powerful engine and not kill your resale. Bet threre are a few members who have moded their L-82's and can give more details. Find out what your mech thinks is wrong and then go from there.
Good luck!
Old Sep 12, 2002 | 05:10 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Looks like you have a great opportunity to upgrade! :)
Old Sep 12, 2002 | 05:17 PM
Mystery Machine
Thanks. I'm just over anxious to know exactly what the problem is. Maybe I'm looking for an excuse to spend some money too. I'm sick!
To Bad News...I think
