Melling cam 22232
Old Aug 15, 2016 | 11:54 AM
RIO68's Avatar
RIO68
Default Melling cam 22232
Anyone make a judgment call on this cam 350 L46 engine stock bore
stock heads...oem dome pistons
lift int--.468 /exh--.480
.50 Duration 220 int 231 exh
lobe ctr int 106 exh 114
thks for any opinions...
Old Aug 15, 2016 | 12:28 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
More of a street cam with some high rpm power. What does your car use for exhaust system and what is your trans/rear gearing?
Old Aug 15, 2016 | 05:02 PM
RIO68's Avatar
RIO68
It's a 4 spd with 2 1/2 chambered exhaust and stock gear on the rear. I assume 3.36 or close there to.
Old Aug 15, 2016 | 06:27 PM
cardo0's Avatar
cardo0
Any headers?
Old Aug 15, 2016 | 07:26 PM
GOSFAST's Avatar
GOSFAST
You need some more L/S for a "streeter"? My opinion only.
We actually use a high number of the OEM L-82 cams, these deliver excellent street manners and performance.
Thanks, Gary in N.Y.
P.S. On many of these type builds we simply use "marine" grind cams if it becomes a "book-grind" (stocking part number) cam.
Old Aug 15, 2016 | 08:13 PM
RIO68's Avatar
RIO68
Any headers?
No, trying to keep it close to original appearance under the hood. Car has AC,PB,PS, PW
Old Aug 15, 2016 | 08:15 PM
RIO68's Avatar
RIO68
This cam appears to be just a step up from the L 82 cam or so I thought.
Old Aug 15, 2016 | 10:50 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The cam you posted is great for your setup with manifolds......
Lot of exhaust duration......
Jebby
Old Aug 16, 2016 | 12:04 AM
cardo0's Avatar
cardo0
Not sure if intk c/l of 106 is to much. I would run a dynamic compression ratio calc first. Also don't know if you're valve springs will handle 0.480" lift?
Other than that the added exh duration will help your exh and the added lift will add torque.
On that cam I would use 1.6 rockers on the intakes only - if I could. This should help move the intk closing/reduce dyn comp and add more torque.
Good luck and hope this helps.
Old Aug 16, 2016 | 10:31 AM
RIO68's Avatar
RIO68
Using factory finned covers don't know if 1.6 rockers will fit them??
Old Aug 16, 2016 | 02:03 PM
cardo0's Avatar
cardo0
Sometimes extra thick vlv cover gaskets will give enough clearance.
Old Aug 16, 2016 | 02:21 PM
bluedawg's Avatar
bluedawg
I would think stick compression (which I don't know for the l46) if it's 8.5 to 1 advertised by gm, then the 106 lsa would help some. Like you, i think it needs headers. But if you aren't going headers the buy a set of the 2.5" rams horns like these
https://m.summitracing.com/parts/sum-g9200n
For better flow then the stock sized manifolds, won't compete with good headers, but definently flow better than what came with it. This also puts the option to run 2.5" duals and a good straight through muffler.
Old Aug 16, 2016 | 02:24 PM
bluedawg's Avatar
bluedawg
Also if you go this route, buy the valve springs with it.
Old Aug 16, 2016 | 02:57 PM
RIO68's Avatar
RIO68
The L46 engine is shown to be 350HP with 11 to 1 CR...does have domed pistons.
To Melling cam 22232
