radiator replacement
Old Aug 17, 2016 | 06:44 AM
Sig1977's Avatar
Sig1977
Default radiator replacement
Seeking guidance on what is the best radiator to replace my original 1977
• Make
• Manufacture
• Tips on replacement
Thanks,
Old Aug 17, 2016 | 07:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you considered having a radiator shop take a look at your original?
Old Aug 17, 2016 | 07:45 AM
Ydnar44's Avatar
Ydnar44
Champion 2 row aluminum
Let me start by saying I'm new here, but this set up works very good for me, radiator was 175$ from jegs
Old Aug 17, 2016 | 09:09 AM
SH-60B's Avatar
SH-60B
(edited) Replacement is straightforward, and you don't have to remove the hood to do it, unless you like extra work. I mean who doesnt? Take the fan off, then the shroud, then the rad.
Last edited by vettebuyer6369; Aug 18, 2016 at 02:23 AM. Reason: conflict segment removed
Old Aug 17, 2016 | 09:47 AM
phil1022's Avatar
phil1022
• Make
• Manufacture
Thanks,
Hello:
I'm looking for an original C3 radiator (to rebuild) and your '77 may be a fit for me. If you're interested in selling it can you provide me with some information concerning the original engine (L48 or L82) and whether the car had a/c? Thanks.
Phil
Old Aug 17, 2016 | 01:50 PM
Reaper19's Avatar
Reaper19
Get a DeWitts, you won't regret changing over to aluminum. I changed mine out in a 1981 and it runs cooler ~185 degrees all of the time here in Florida.
Old Aug 17, 2016 | 05:06 PM
Ibanez540r's Avatar
Ibanez540r
Nothing towards the OP, but here we go again...
...admins, maybe we should make a sticky containing the 50,000 links to this topic and label it "If you are about to post a question regarding replacement radiators, READ HERE FIRST". They all have the same information and argument.
Old Aug 18, 2016 | 01:58 AM
The13Bats's Avatar
The13Bats
• Make
• Manufacture
Thanks,
depends on what you have, what you want, and your budget
I like the extra aluminum shroud so no radiator is wasted very nice and thanks for the picture...
A non biased sticky on this subject would be nice to link to when a thread like this gets posted....
Old Aug 18, 2016 | 02:21 AM
vettebuyer6369's Avatar
vettebuyer6369
Here's the first page of the first 20 pages of matches for aluminum radiator threads in C3 TECH alone.
If someone would like to take time off from work and assemble a list of links (I think these start in 2002), I'll be happy to set up a Sticky.
Old Aug 18, 2016 | 08:52 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Just find one that is full of DeWitts slappys and post that one. No need for anything else
Old Aug 20, 2016 | 07:17 AM
Sig1977's Avatar
Sig1977
You then should consider developing the same for:
- Types of Oil
- Recommended Tires
- Recommended Ball Joints
- Recommended Shocks
- Recommended ETC
I see the same questions over and over
Thank you for making me your poster child
Old Aug 20, 2016 | 07:19 AM
Sig1977's Avatar
Sig1977
Originally Posted by phil1022
Hello:
Phil
Hi Phil,
My 77 has the L82 Eng. Manual, No A/C
Regards,
Mike
Old Aug 20, 2016 | 12:10 PM
USAFVeteran's Avatar
USAFVeteran
I went through 5 radiators, none of them worked, or fit properly. I don't care what anybody says here, or what kind of attitude they may have (and that's just fine too) but I purchased a DeWitt's for my 69 that has a 454 LS-1 installed before I bought it. It is a small block core support, so I got a small block radiator. It has cooled my 454 in the Tucson, AZ heat.
Old Aug 20, 2016 | 01:41 PM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
I'm sure that in a few of those previous threads on radiators there'll be posts from me recommending these guys: http://www.completeradiators.com/
A super competitive price, first class customer service and help, rapid and well packaged delivery to me here in France and... yes, it was an EXACT replica of the original and we could have slotted it in blindfolded! So effective was it at cooling the car, I had to install a new thermostat, as the one in place was clearly chosen to match the cooling (or lack of) done by the old rad!
Just my thoughts
Old Aug 20, 2016 | 10:48 PM
The13Bats's Avatar
The13Bats
• Make
• Manufacture
Thanks,
I will try this out on you, there has been a lot of furor with radiator/cooling threads lately.
Please see if this write up I did is of any help to you...
Seems cooling and radiators are a popular and very much posted subject on the Corvetteforum, and with that many questions are repeated and I am hoping in a general way to shine a little light on the subject of radiator selection, I do not claim to be the guru on the subject.
Many times people with a cooling problem are thinking of replacing the radiator when it might not be necessary.
Things to check first when considering a new radiator include, is what you consider "overheating" really too hot?
Personally for me in Florida I like it to always be well under 210 an no creeping at any time.
Is the gauge reading correctly? the ignition timing, the factory front spoiler/air damn, the seals around the radiator to be sure the air is going where it should.
The water pump could be going out.
The thermostat could be malfunction or completely stuck, check the radiator hoses if they feel spongy or the lower hose doesn't have the spring it could be collapsing.
So when you determine you do need or desire a new radiator you have to decide what is correct for you.
In many cases on a stock or mild engine all you need is brass replacement and for many years that was cheaper than Aluminum but that has changed a little,
a base model Aluminum radiator is now the same or cheaper than a brass radiator making the Aluminum aftermarket radiator look pretty good to all except the purist who needs exactly what came in the car.
There is a lot of debate which cools better copper or aluminum and that debate will likely never be 100% agreed on by all so I will just touch down on a few basics,
Science proves copper actually transfers heat better, however, many copper radiators are still made in a way that is soldering different metals together and where joints come together with solder some cooling ability is lost, these joints were also a source of bloom in some of the copper radiators depending on how they were made.
Aluminum radiators are welded or brazed at the joints and are all aluminum and do not loose cooling at the joints.
Aluminum is lighter than copper which is a perk for many people.
Aluminum radiators tend to use wider tubes for more surface area than copper so a two row aluminum in general cools the same as a 4 row copper.
Both Copper and aluminum radiators need to have proper "coolant" for corrosion and antifreeze protection where needed and recommended by radiator manufactures most people and techs agree a good 50/50 pre mix does the job.
And now the dreaded question, "Which aluminum radiator should I buy"
On this forum it would seem we have two favorites always surface so in this corner the Dewitts and in the other corner the import or "Champion".
Lets start with the Dewitts,
A long running contender with a well known and trusted name with Corvette owners, Dewitts is considered a top end brand like Griffin or BeCool.
They are made in a special brazing oven built for this purpose and are nothing short of a work of art for your car.
Dewitts pride themselves on fit, to my understanding more so than Griffin or BeCool,
many times even stock parts can be tricky to fit but the Dewitts radiator has a lot of time spent in design behind it to make sure it is as plug and play as you can get with a radiator, and if you do have an issue Tom Dewitt is a phone call or forum post away.
As far as cooling goes the Dewitts will cool what you have and look super doing it no questions there
If the Dewitts has any cons some people feel the price is high, but this is a part proudly and very well made in America and is competitive priced with the other top names out there.
Now the import unit or Champion.
This aluminum radiator that has been gaining attention and being used by many 68-82 corvette owners for the main reasons, the low entry price and it does the job.
I noticed what I would call quality control issues with some, one fellow would say his welds looked like bird dropping or bubble gum and the next would say they looked beautiful like a roll of coins laid out.
I have heard several people report back that they had to bend this or tweak that to fit the Champion in their car.
All the users do report they are happy with it and it does what a radiator is suppose to do and they saved a little money for other things on their build.
What we have with the champion is short term feedback, how will these units do over time, will they hold up like their top name competitors or will longevity be reflected in their lower pricing, we will have to wait ands see with that question.
I also learned that while the "Champion" is the "budget" name on this forum Ebay has an influx of even lower priced aluminum imported radiators, this got me to thinking at some point how does even import companies sell and make a profit at such low prices, and I am betting the metal gets thinner and thinner as price goes down, that would just make sense.
Feedback reflects poor fit and damage in shipping.
I am not picking sides or debating which is better, both are, neither are, each persons build is going to be different so they will have to pick the one that is "better" for them.
Old Aug 20, 2016 | 11:05 PM
vettebuyer6369
- Types of Oil
- Recommended Tires
- Recommended ETC
Let's try again. There's nothing remotely comparable regarding tires, ball joints, shocks, or recommended etc, to these radiator threads that are constant and repetitive. Oil, yes.
What did we do with oil? We let people who are passionate about them create a huge thread that has become a sticky, which is exactly what I suggested people do who wanted a radiator sticky done.
Sometimes people insist on starting new oil threads, and generally they get to repeat themselves for awhile before we close them, as will happen with this thread.
Nobody made you a poster child. You asked a question that is addressed constantly, it was suggested that the mods start a sticky, and I pointed out that if someone would like to aggregate the threads easily found in a search, I'd do that.
The next time you have a question, feel free to send a PM.
Old Aug 21, 2016 | 08:14 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
No reason to hide. i thought that was your best post ever. Good enough for the mods to make a sticky and you could retire.
Old Aug 21, 2016 | 08:55 PM
vettebuyer6369
I think that's a good idea, Tom.
While I'm not interested in linking up all the old threads, I believe I will start an aluminum radiator discussion thread in the Stickys to see if we can cut down on the repetition and help those who don't search well.
Bats, I'll start the thread with a quote of your latest post on the topic. Anyone who routinely posts in the radiator threads, feel free to join in.
I think that will close this thread as well.
Edit: here's a link to the new Sticky: https://www.corvetteforum.com/forums...ed-topics.html
To radiator replacement
