1971 C3 LT1 stalling issue
I have a stalling issue with my 71 LT1. When the engine is warm the car will cut out when in neutral, traffic lights etc. No issue when the engine is cold. I have done some research and people talk of a fuel vacuum issue. Any ideas?
thx dave H
What is your normal idle RPM? Is this something where that could be bumped up a small bit?
Do you happen to have a vacuum gauge you could plug into the carb? You'd want to put it on the lowest port which sees the intake vacuum after the throttle plates.
You could also start disconnecting vacuum-operated items to isolate a potential leak. Start with the vacuum advance, then move on to the accessories. There's a whole lotta hose that goes to the headlight and wiper assemblies. Many potential leaks if the hoses, fittings, and baffles are anywhere near original.
Not sure if that sounds like your problem or not, but I figured I'd toss the thought out there. An item that is sometimes overlooked.
Idle 600 RPM, I tried bumping it up and its doesn't help. Seems that when the engine is hot the fuel evaporates at idle. Not sure how to resolve. and yes manual box.
Most auto places should still sell rubbers to block off the vacuum lines. Isolate your carb at idle (remove all vacuum lines and block off with rubber stoppers/covers) and I'd be surprised if your car didn't miraculously run better.
I'd also remove and block off the PCV. Those go bad too.
Just get the engine to nothing but carb, engine, and exhaust. For the sake of completeness, check the timing and the plugs. If it is an LT-1, you don't have to worry about points.
An outside possibility would be a weak coil, but I would think that would be an issue when winding the engine up, not when idling.
Then comes the awesome task of finding the leak.
Ok, not really, I'm wondering if I have the same problem. The float height issue seems to be a reasonable explanation for what I'm experiencing, maybe you could enlighten me. If you think it sounds like my issue, maybe you could tell me how to fix it?
1975, L48 4 speed, but with a new Holley 600 on it. HAD been running fine, but I hadn't put many miles on it. After it gets warm, it feels very sluggish after a slow down or stop. Like it's loaded up. Not firing clean, but after a bit of throttle it cleans up. Definite chugging though.
Most recently, once warm it will die as I'm braking. Tach will show it stuttering at about 3-400 rpm as I'm braking, and sometimes die. No start unless I floor it, then it fires right up. If I don't touch the gas pedal it won't fire. It also smells of gas when I park / stop it, after one of these little episodes.
Tonight it let a huge puff of smoke after sitting for a bit after running like a$$ on the way home, not sure if it's related though.
Hopefully it's similar to what the OP is experiencing, and my symptoms/diagnosis can help him as well.
Thanks for the posts so far, I'm interested in the black magic /voodoo thing under the breather!
Isolate all vacuum accessories. then see how the engine runs.
after that you can start tweaking carburetor.
tho vacuum could be the problem. but his problem is only when the car is warm. meaning it runs wells cold. vacuum trouble is consistant.
Try hooking the vacuum can directly to manifold port, if it is not already setup that way.
If it is a fuel level problem, you now have to fix what's causing it. If you haven't fiddled with the float level, it's not likely to be an adjustment issue since they don't go out of adjustment. You then have to investigate the float to see if it's sinking or if the needle and seat is faulty or if the o-ring in the seat is bad. It could also be a fuel pressure issue that is highlighting deterioration of the needle and seat assembly. And you might just have some debris trapped in the needle. Hard to know until you start checking things out.
Just to elaborate, I just bought the car, and the previous owner had installed an Edelbrock intake and Holley carb prior to selling it. I do have the originals but am keeping the new parts on it. I'm not sure who installed the new parts, as the cheap bolts on the intake and silicone patching the coolant inlet at the intake manifold shows me a complete in attention to detail.
The problem, is now all time however. Every stop, idle goes down to 3-400, chugging, hold your breath, comes back up and works fine after a second.
I'll start looking into your suggestions, but one thing just occurred to me that I've changed when this started. The PCV into the valve cover was wrapped in tape to seal, and I peeled the tape off just letting it sit. It looked brutal, but maybe it was there for a reason? Is there vacuum there that could cause the issue? Maybe I did it to myself lol... I'll start there!
Really appreciate the detailed replies, sorry I didn't get back to the thread with better details sooner. Our Country was closed for anything and everything yesterday due to the Tragically Hip final concert. Drying our tears and getting back to life today.
