A/C air flow
Old Sep 12, 2002 | 08:20 PM
Moshjr's Avatar
Moshjr
1st Gear
Default A/C air flow
The motor is currently out of my 75 convertible and I want to test the airflow through the vents in the interior. The heater and defroster work fine, but I don't get much airflow throught the center and side vents. I want to test the door opening in the engine compartment. My question is (finally) is the door vacuum operated or electric? I suspect vacuum but not sure.
Any help is appreciated!
Arnie
Old Sep 12, 2002 | 08:24 PM
Larry B.'s Avatar
Larry B.
Default Re: A/C air flow (Moshjr)
All of the A/C doors are vacuum controlled. Heater (Temperature) door is cable operated.
[Modified by silvervetteman, 7:24 PM 9/12/2002]
Old Sep 13, 2002 | 12:51 AM
Rods77's Avatar
Rods77
You may want to check the ducts at there connection points with each other. When I had the dash out of my 77 I noticed about a 1/2" to 1" gap between the ducts at the plenum behind the stereo, picked up some of that A/C tape from Autozone and sealed everything up. Works great.
To A/C air flow
