Telescopic column spring for horn
Old Sep 12, 2002 | 10:45 PM
Pace Car 07's Avatar
Pace Car 07
Default Telescopic column spring for horn
Horn doesn't work on my 69 vette and when we dismantled the column found that there is apparently supposed to me a large 2-3" diameter spring that keeps the horn contact plate moving up and down when the column is adjusted in and out. Anybody know if these are available from the parts houses. I am researching the GM part number also. Mechanic had an exploded view of telescoping columns for 69 GM cars that shows the spring. It does not show in the 69 vette Assembly manual.
All advice appreciated
Thanks,
Old Sep 12, 2002 | 10:48 PM
lbell101's Avatar
lbell101
Default Re: Telescopic column spring for horn (69lemansblue)
You can get almost any column part over at doc rebuild.
Old Sep 12, 2002 | 11:24 PM
Jim Shea's Avatar
Jim Shea
Default Re: Telescopic column spring for horn (lbell101)
I have the AIM sheet for the 1969 T&T column as well as the AIM sheet for the 1975 T&T column. Even though the 1969 illustration doesn't show the large spring on the underside of the lower horn contact assembly, it is the same part number as the 1975 column part. It is not available from GM. Dr. Rebuild does list the part: 1969-75 Lower Horn Contact 2819109 $35.
Old Sep 12, 2002 | 11:37 PM
Pace Car 07
Thanks guys, I will pursue the spring at both places and see what I find.
Chuck
Old Sep 12, 2002 | 11:43 PM
bl75vette's Avatar
bl75vette
While you have the column open, you might want to look near the directional signal plastic contact butt'y. I had a problem with my horn contacts and discovered the lower contact was depressed or pushed in and not contacting the contacts that connect to the spring butt'y that brings the voltage to the upper contacts.
Old Sep 13, 2002 | 01:04 AM
Jim Shea's Avatar
Jim Shea
Default Re: Telescopic column spring for horn (Jim Shea)
BTW, the GM part number is 3949105 if you can find it.
Old Sep 13, 2002 | 02:40 PM
verskel's Avatar
verskel
Sorry I couldn't help.....my '68 didn't come with telescopic ! :jester :lol:
To Telescopic column spring for horn
