Carburator
Old Aug 26, 2016 | 12:33 PM
harman27@yahoo.com's Avatar
harman27@yahoo.com
8th Gear
Default Carburator
I have the original carb on my 72 was thing of putting a edelbrok on it any thoughts
Old Aug 26, 2016 | 02:14 PM
Revi's Avatar
Revi
"I have the original carb on my 72. I was thinking of putting an Edelbrock on it. Any thoughts?"
A properly rebuilt and tuned Quadrajet is all that your car needs. Installing an Edelbrock will not increase HP or performance.
Old Aug 26, 2016 | 05:18 PM
V4motorsports's Avatar
V4motorsports
Originally Posted by lars
That's a great idea if you'd like to lose 10-15 hp over the stock Q-Jet.
Oh snap!!!!!!
Russ
Old Aug 26, 2016 | 05:20 PM
Shark Racer's Avatar
Shark Racer
The 400 in my 78 made 450hp/485tq with a 78 M4M QuadraJet.
I also took it out to autocross and had a blast - throttle response everywhere, no issues in any high-G-load situation.
Old Aug 26, 2016 | 10:05 PM
harman27@yahoo.com
8th Gear
I'm a new owner of my dream car. Just starting to learn the ins and outs. Is there a limiter on the tax after 4500 rpms.
Old Aug 27, 2016 | 05:25 AM
7T1vette's Avatar
7T1vette
You mean 'tachs' ? No, there is nothing that should prevent the tach from reading correctly. But, the tachometer could have an internal problem, the drive cable could be worn, or the worm gear in the distributor could be shot.
If the engine just won't rev past 4500 rpm, it is probable that the secondaries in your carburetor are not opening at all...either because the throttle cable/linkage/accel pedal are not allowing the carb to open fully, or because the secondary lock-out tab on the carb is not releasing when the choke is fully open.
Old Aug 27, 2016 | 12:06 PM
Revi's Avatar
Revi
Maybe you could post some pics of your car and carb?
One item that you can check is to make sure the secondaries are opening as they should.
With the engine off, remove the air cleaner assembly, manually hold the choke open, manually hold open the air valve and have someone push the accelerator all of the way to the floor. Look down into the secondaries and see if they are opening all of the way. If not, adjust the throttle cable as needed.
Old Aug 27, 2016 | 04:46 PM
ykf7b0's Avatar
ykf7b0
I personally would rather have your quadrajet needing a rebuild vs a new Edelbrock on my Corvette.
Old Aug 27, 2016 | 05:56 PM
7T1vette's Avatar
7T1vette
It is easiest to change the fuel pump by jacking up the right-front and removing that wheel. Access is much better. You also want to burp the engine over to where there is minimal load on the fuel pump actuator arm (actuated by cam lobe). You can get it OFF, ok; but putting it back on with load on the arm is tough.
Old Aug 28, 2016 | 08:12 AM
harman27@yahoo.com
8th Gear
Thanks guys I will post a pic later on
Old Aug 28, 2016 | 09:28 AM
Ydnar44's Avatar
Ydnar44
Is this true?
Old Aug 28, 2016 | 09:34 AM
Ydnar44's Avatar
Ydnar44
Originally Posted by Ydnar44
Is this true?
Oops, just went through Lars's posts, he's probably right
Old Aug 28, 2016 | 11:00 AM
harman27@yahoo.com
8th Gear
I've done a ton of dyno testing on the engines that I build, and for every dyno run, we always bring several carbs with us to test on each engine combo. On the dyno, each carb tested is verified to be set up correctly, and air\fuel ratios are all set identically on each carb to produce best power and torque curves. Consistently, and without exception, the Carter AFB carbs (aka, "Edelbrock Performer"), of the same cfm rating, will run at power levels about 10-15 hp below a correctly set up Q-Jet or Holley-type carb. So I never use them on a performance engine - there are better choices.
However, let me say this: There are a lot of very badly set up Q-Jets (including the dreaded Commercially Rebuilt Carbs) out there. The EDL "Performer" carbs are set up to run reasonably well right out of the box. If you don't have a carb for your car, or if your Q-Jet is screwed up beyond all help, the use of a "Performer" is a quick and easy way to get the car running reliably. It won't be optimum, but it will start and run with no issues and no special tuning required. If peak performance is not your agenda, and you just need to get the car running with a modestly-priced new carb, the "Performer" may be a good solution for you.
Very informative, the gentle men I bought the car from said that he just had it rebuilt so now I'm wondering should I try and find someone to go over it. Just for piece of mind
Old Aug 28, 2016 | 01:10 PM
harman27@yahoo.com
8th Gear
How do you add a photo
Old Aug 28, 2016 | 01:31 PM
harman27@yahoo.com
8th Gear
If you need more I can do it now thanks
Old Aug 28, 2016 | 01:32 PM
harman27@yahoo.com
8th Gear
Boy that was hard
Old Aug 28, 2016 | 01:47 PM
AboveTheLogic's Avatar
AboveTheLogic
It looks like someone did away with the original pipe that runs from the fuel pump to the carb and used rubber instead, on the pressure side.
To Carburator
Old Aug 28, 2016 | 08:36 PM
harman27@yahoo.com
8th Gear
So what does that mean? Is that a performance problem?
Old Aug 28, 2016 | 08:47 PM
Peterbuilt's Avatar
Peterbuilt
No! Not a performance problem, a fire hazzard.
It's preferred to have a hard line on the pressure side of the fuel pump.
All the vendors offer that line pre-bent.
Old Aug 28, 2016 | 11:13 PM
AboveTheLogic
Right, not performance at all. Fire hazard and an indicator that someone has been in there changing things.
