Turbo 400
Old Aug 27, 2016 | 06:34 PM
71454's Avatar
71454
Default Turbo 400
Can anyone tell me if the vent tube on a turbo 400 has a screen? Looking for help my 71 454 turbo 400 sometimes pushes fluid out the dipstick sometimes. Car isn't driven much.
Old Aug 28, 2016 | 02:33 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No it's...just open. It could be plugged somehow..but seldom happens.
Are you sure of fluid level? Not overfilled?
JIM
Old Aug 28, 2016 | 05:27 AM
7T1vette's Avatar
7T1vette
The vent is at the top of the right side of the main case. It has a roundish metal cap on a threaded metal tube that screws into the case. If your trans has been rebuilt at some shop, they could have left the vent off or could have put a plastic cap in there, but forgot to remove it and put the vent in.
You could also have too much trans fluid in the unit. Trans fluid level is checked with engine running and up to temp. If you set level when "cold", it will have too much fluid in it.
Old Aug 28, 2016 | 10:48 AM
71454's Avatar
71454
JIM
Not over filled, tried to push a wire up it but stops, guess I better try and push something thru.
Old Aug 28, 2016 | 03:03 PM
7T1vette's Avatar
7T1vette
The metal cap on the tip of the threaded pipe won't allow a solid object to escape. It's designed to let air out and keep other 'stuff' from getting in. Sounds like it's doing its job.
Are you sure that the dipstick in your trans fill tube is correct for the unit? Fill tube and dipstick are a set? Possible that the 'full' mark is not at the right spot for that trans? Symptoms indicate an over-full transmission sump.
Old Aug 29, 2016 | 10:51 AM
71454's Avatar
71454
[QUOTE=7T1vette;1592941847]The metal cap on the tip of the threaded pipe won't allow a solid object to escape. It's designed to let air out and keep other 'stuff' from getting in. Sounds like it's doing its job.
Are you sure that the dipstick in your trans fill tube is correct for the unit? Fill tube and dipstick are a set? Possible that the 'full' mark is not at the right spot for that trans? Symptoms indicate an over-full transmission sump.[/QUOTE
there is no cap on tube, just a 3 or 4 inch tube on top right side of tranny, yes right dipstick car is very original I've owner the car for 20 years this is a new one! Doesn't do it all the time crazy!!
thanks
To Turbo 400
