Heat Riser Clarification on 1978
Old Aug 28, 2016 | 12:18 PM
blanman61's Avatar
blanman61
Default Heat Riser Clarification on 1978
Just want to make I understand this correctly. The heat riser on my 78 is open when the vacuum operated arm is fully extended (no vacuum) and closed when it is retracted (with vacuum on). This is what I understand from looking at other posts. Plan to remove it eventually but for now want to make sure it is open. Thanks
Old Aug 28, 2016 | 12:49 PM
tracdogg2's Avatar
tracdogg2
You are correct.
Mike
Old Aug 28, 2016 | 01:00 PM
blanman61's Avatar
blanman61
Thank you Mike!!
To Heat Riser Clarification on 1978
