Crossfire ignition timing
Old Aug 29, 2016 | 09:47 AM
icpr4u's Avatar
icpr4u
Default Crossfire ignition timing
Other than setting the base timing on an 82 crossfire is there anything else I need to do? (Yes, I disconnected the EST wire first.)
The computer takes care of setting the advance right?
Old Aug 29, 2016 | 03:00 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, the computer will take care of it.
Just know that after you make (almost) any adjustment to your car, there computer will need to "reset" itself. Drive around for about 15 minutes and make sure you go over 35mph for an extended stretch.
Also, make sure your TPS is bang on prior to adjusting the timing. If you don't your computer will get mixed signals and run rough.
So... First do the TPS and second adjust the timing. Mine likes 12 degrees.
Old Aug 29, 2016 | 06:55 PM
DUB's Avatar
DUB
AND this is ASSUMING that the notch in your harmonic balancer is CORRECTLY positioned so when you use your timing light...you are actually timing it to what you want...and I have dealt with MANY harmonic balancer outer rings that have spun and thus ...the timing light is USELESS....because the notch is not in the correct spot for timing.
DUB
Old Aug 29, 2016 | 10:03 PM
icpr4u's Avatar
icpr4u
DUB
yea I am ASSuming it is for now but thanks for the heads up. I'll file that away in case I need it
Old Aug 30, 2016 | 09:06 PM
terry82's Avatar
terry82
http://www.superchevy.com/how-to/512...right#cxrecs_s http://www.superchevy.com/how-to/468...system-tuning/
To Crossfire ignition timing
