I have the original 2 bolt 350 block in my car. Also using a cast, stroker 383 crank and original, reconditioned rods. I do have forged pistons. I have about 10,000 street miles on it and over 250 quarter mile runs, currently running low 12s at 109/110 mph. This setup can be duplicated far cheaper than an LS conversion would cost and is far easier to do. Just my experience.
I've built several pretty potent small block drag engines based on a 2 bolt block.a set of splayed caps work very well. The cast crank is probably ok to about 350 horsepower which is more than an ls1 makes.
The small block chevy is an excellent foundation for a performance build. The LS series engines are a fine engine without a doubt, but they aren't that cheap .the small block chevy has won alot of races and powered alot of pretty fast street cars in its 60 years, and it's not done yet.
The main reason it's a dog is the low compression ratio. Rebuild it with the right carb, intake, cam, and headers, and 10:1 compression, you'll be happy.
Not to hijack the thread, but based on your avatar are you running slicks? If so, what did you do to beef up the rear suspension, half-shafts and differential?
Thanks,
Mike
Well it looks like I'm not gonna get the phone number of the guy who actually knows what's all up with this vette, but thanks for all y'all have told me. It is always good to have opinions.
