Fan blower ac questions
Old 09-02-2016, 02:29 AM
lancer013
lancer013's Avatar
Default Fan blower ac questions
I have a 82 corvette and want to get the ac back up and running im getting power to the blower with switches on and when off not getting any power should i change the blower first the ac turn but does not engage when i press the gauge button
Old 09-02-2016, 03:49 AM
usmilret
usmilret's Avatar
Connect a multimeter to the positive side of the wiring to the cab blower motor. turn on the AC or fan and check if you are getting 12vdc. Check for a good ground at the black wire. If all is good then replace the cab blower motor.
Old 09-02-2016, 03:58 AM
lancer013
lancer013's Avatar
Thanks will do what is the best access to get into there if i have to replace it
Old 09-02-2016, 04:03 AM
usmilret
usmilret's Avatar
Remove the engine coolant overflow tank, three bolts. You can make the check without removing anything.
Old 09-02-2016, 09:57 PM
terry82
terry82's Avatar
with what has been said.check the fan motor for power first.after you take out the overflow tank the fan motor will come out .it does not look like it but it will .you may have to move the ac line.i also added a better ground wire for the fan motor.If you have no Freon in the system the ac clutch will not engage.
Old 09-03-2016, 02:21 PM
lancer013
lancer013's Avatar
Im getting 12v from the wires so i guess ill order a new fan how do i move the ac line i cannot remove the coolant tank line does not move
Old 09-03-2016, 03:34 PM
terry82
terry82's Avatar
pull it away by hand so that you can get the fan and motor out.It will come out.
Old 09-18-2016, 05:33 PM
lancer013
lancer013's Avatar
Taught
To Fan blower ac questions
Quick Reply: Fan blower ac questions
