Temp gauge ceramic bridge
Old Sep 6, 2016 | 09:30 AM
Joebrick's Avatar
Joebrick
Default Temp gauge ceramic bridge
Can someone tell me the purpose of the ceramic bridge in the temp gauge of our cars? Mine is broken in half, however the gauge works fine.
When I found this I just reinstalled in two pieces without issue....does it just insulate?
I've heard it referred as a ceramic resistor, but this makes no sense.
Old Sep 6, 2016 | 12:23 PM
Alan 71's Avatar
Alan 71
Hi Joe,
I believe the resistor is located below the ceramic bridge.
This video from Willcox may help you!
Good Luck!
Regards,
Alan
Old Sep 6, 2016 | 01:49 PM
Joebrick's Avatar
Joebrick
Thanks Alan,
I guess my question is more about the purpose of the white ceramic bridge above the resistor. Mine is broken in half but "in place". Bugs me that its broken, but the gauge seems to work fine.
My guess is that it isolates terminals and does nothing more than that.
Old Sep 6, 2016 | 02:25 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Originally Posted by Joebrick
Thanks Alan,
It serves a few purposes which, fortunately for many of us, are not compromised by it remaining in one piece.
  1. Holds the plug terminals at the correct height and orientation for the plug
  2. Insulates the terminals from the gauge cluster housing (note that the studs are insulated by plastic right where they come through the cluster holes)
  3. Serves as a heat sink for the wire wound resistor
To Temp gauge ceramic bridge
