68 windshield wipers
Old Sep 7, 2016 | 04:31 PM
carlisle61's Avatar
carlisle61
Default 68 windshield wipers
Please tell me which blade is on the top when wipers are in the parked position. Thank you Ernie
Old Sep 7, 2016 | 05:21 PM
One Owner's Avatar
One Owner
Lifelong Vette Lover
Don't know if the 68 wipers are the same but my 69 has the driver side wiper blade on top. I did restore all the wiper arms, components, etc. and believe I reinstalled them correctly, so hopefully this is the correct answer. That said, I'll defer to others but hope this helps, Ernie.
Jack
Old Sep 8, 2016 | 10:20 AM
Alan 71's Avatar
Alan 71
Hi c,
Jack may be correct for 68-69 cars but for 70-72 cars I'm quite sure the left side wiper parks first and then the right side.
I believe this has to do with the 'lever' on the right side wiper transmission that cycles the wiper door interlock which signals the door actuator to close once the wipers are parked.
I'm pretty sure it's the same sequence for 68-69, but not positive.
Regards,
Alan
Here you see the right side arm with the lever which pushes on the safety switch plunger. This arm has to park last or the door would close on the left wiper arm. The circled screw adjusts the blade's sweep. I added it when I used this picture before for another question.
Old Sep 8, 2016 | 10:55 AM
One Owner's Avatar
One Owner
Not surprisingly, I think Alan's right.
I did go back and look and sure enough, there is a squat switch or something that the passenger side wiper arm/linkage depresses when it parks. There is no such animal on the driver's side. Therefore, Alan's logic that the passenger side closes last is sound. My car isn't running yet and I've not used the wipers, so it looks like I've got some adjusting to do.
Thanks, Alan!!
Old Sep 8, 2016 | 11:18 AM
Alan 71's Avatar
Alan 71
Hi,
Here's a better photo of the safety switch and the lever that depresses it's plunger.
Regards,
Alan
The wiper arm isn't installed on the transmission's post.
Old Sep 8, 2016 | 08:08 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Early 68s dont have that switch.
Passenger side on top. Everything is in the aim on adjustment. Keep the windshield wet while adjusting so they dont drag. It can affect the parking. I used a squirt bottle and water. It takes some fiddling with the arm angle and the transmission adjust. Take your time.
Old Sep 9, 2016 | 06:39 AM
carlisle61's Avatar
carlisle61
Default 68 wiper door
Thanks my car is a Sept 67 build, and I could not find that switch.
Old Sep 9, 2016 | 07:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Early 68s dont have that switch...
Ditto for the late ones.
Old Sep 9, 2016 | 08:46 AM
Alan 71's Avatar
Alan 71
Hi,
Well that answers that!!!!
No safety switch on 68 model year cars, left side down first , then right side!
Regards,
Alan
To 68 windshield wipers
