Hi guys I am installing 454 and tremec 5 speed in my 76 .I have McLeod clutch ,pressure plate and bell housing. Car was originally automatic so I purchased all clutch lineage from cc. Throwout bearing came wit clutch. My problem seems to b the clutch fork is too short its not centering throw out bearing on pressure plate.or is it that throw out bearing not correct.any help would b appreciated thanks
When you install altered parts like i did with a blow proof bell housing, block saver plate, and thinner SFI rated flywheel. You need an altered length pivot ball.
GM sells a longer stock pivot ball or you can buy adjustable pivot *****.
You can look up you tube videos on throw out bearing installation. Maybe watch one and it shows how to clip it in correctly
Thank you for ur reply .throw out bearing is installed correctly. Don't think a longer pivot ball will help.will that move it more towards the center of pressure plate
When the pivot ball is the correct length the throw out bearing and arm are 90 degrees to the input shaft at rest and some low clearance number to the PP fingers. This is your free play of the clutch petal. I usually try to set the clearance to .040 - .060
GM only made one length arm that I know of and after market bell housings are made to use standard parts
That's not possible. The fork does not position the TO bearing - it only engages with the TO bearing while the bearing "floats" in the fork. The position of the bearing is determined by the bearing slipping onto the transmission's input shaft housing. If the bearing is not centered on the pressure plate, you are implying that the entire transmission input shaft is not on crankshaft centerline, and that's not possible...
Yes, you do. Get one of the adjustable ***** (like Lakewood) and set it exactly 1/8" taller than the stock ball. This will get the geometry very close to perfect.
