LT1 1969?
Old Oct 18, 2012 | 07:27 PM
Brcmpbl's Avatar
Brcmpbl
Don't need leaded gas or any additives to run an 11:1 engine. The L46 also has 11:1 compression and runs fine on premium pump fuel for the most part. Also someone might have addressed this above but the L46 has a 6000 red line tach. The LT1's is 6500.
Old Oct 19, 2012 | 11:42 PM
LT1driver's Avatar
LT1driver
redline on l46 due to hyd cam, numbers stamped on pad tell whether lt1 or l46, but other than that you could add all required pieces and make l46 look and run like lt1. also lt1 had trans ignition, different u-joint pieces(like bb..caps not u straps)
Old Jun 9, 2022 | 05:24 AM
jzjunkie's Avatar
jzjunkie
5th Gear
Default lt-1 article
I found a pdf of the original article from july 1969 you can get it here http://www.deansgarage.com/wp-conten..._Test_1-17.pdf
