Was too high-now too low
I have a 1970 no option car with stock suspension(except a 15+year old set of KYB shocks). My Corvette sat perfect until I put on a set of aluminum heads a couple of years ago.Then it sat about an inch taller than it was before.
I just completed a new ball joint and tie rod end project and took one complete coil off the front springs thinking it would lower the car 1 inch. Now it sits too low. It is 26 inches from the ground to the fender lip.
Is there a "safe" way to raise the car an inch or am I stuck buying new springs? I know I should buy new springs and shocks but the Mrs. said no more Corvette parts until She gets new floors.
Received 3,139 Likes
Coil spring spacers are available from spring shops or summit/jegs. Various thicknesses and materials
M
M
GM used to sell air conditioning spacers, basically a piece of hard rubber that went under your coil spring, I have them in my #1 below, mine might have come from Moroso
Before you add the spacers, read the section on proper suspension measurements in the AIM. The present height might be OK. IMO, I like the way it looks, it is similar to my 70 BB.
