Easy Side Pipe Removal
Old Sep 13, 2016 | 01:05 PM
cbrock's Avatar
cbrock
Default Easy Side Pipe Removal
To make getting the side pipes off a walk in the park I did the following:
1) Bent mounting tabs horizontal
2) Welded T bolts to frame
3) Cut off the expanded portion of the pipe with nut/bolt squeeze clamp
4) Used stainless steel band clamp (cut off excess bolt length)
Now I can have both pipes on the deck in 5 minutes and they will never cease in place
