autocross spring choice?
Old Sep 16, 2016 | 12:44 PM
corvettedave383's Avatar
corvettedave383
Default autocross spring choice?
ive got a 78 vette, which will have high bhp, 335/30/18 rear tyres and 285/35/18 front tires, qa1 double adjust full coilover upfront with 550 spring and have qa1 double adjust shocks at rear, looking to update my rear mono spring, to a new mono spring, what would be the best spring rate for the rear 300, 360, 400, 420 ???
will be used for street and plenty trackdays, autocross
anyone help, thanks
Old Sep 16, 2016 | 03:57 PM
gkull's Avatar
gkull
First you need to figure out how much squat and body roll you have with your existing springs and go from there. I had people take still and videos of my 79 drag racing and on a road course.
I added a leaf to make it 500 lbs rear and my 550# coils from VB&P on inch shorter. I ran it that way for many years and then decided that adjustability on ride height was needed.
So I installed the QA-1 dual adjust front with 650# springs. I also have 600 and 700#
Then I decided to loose some weight and I went with a rear VB+P 420# mono. and 3/4 rear sway. My first day at the track my slicks were into and rubbing the rear wheel flares. So I cranked up the bolt to lift the rear end to finish out the day. On monday i called VB+P and said that the 420 was no good for me and I needed about 500# so they made me a 520# and that really works nice. with my rear dual adjust
Old Sep 16, 2016 | 04:24 PM
corvettedave383
thanks for info, looks like i need to start fairly high 400 +, try and then if not right, try a different one
Old Sep 16, 2016 | 04:35 PM
v2racing's Avatar
v2racing
I think the reason George had to go up on spring rate in the rear is steel springs are progressive and fiberglass springs tend to be linear. If he would have had a 420 pound steel spring, it's resistance to the forces would have progressed as a rear corner was pushed down stopping it from reaching the point of tire rub. It's why some racers prefer steel. Going up on spring rate fixed his problem though so they both work, just differently.
Car weight, traction, balance (weight distribution), power, overall setup and driving style can all affect what is needed for springs and shock adjustment. You'll have to experiment.
Old Sep 16, 2016 | 06:44 PM
gkull's Avatar
gkull
I wish Bee Jay would chime in.............. he auto crosses his lightened 78 with my 420# mono. He also has a 383
Old Sep 16, 2016 | 09:34 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I started with a 360# composite rear spring a bunch of years ago (but removed the rear bar to reduce the snap oversteer that C3s are prone to on occasion), but after a couple years of autocross and track days I changed to a 420# piece. I liked the feel and handling of the car better with the 420# spring.
I've since put a C4 suspension under the car, and am running the (500# IIRC) Z51 rear spring.
Old Sep 17, 2016 | 12:29 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Have You added a rear Sway Bar since the C4 conversion ?
Old Sep 18, 2016 | 08:14 PM
69427's Avatar
69427
Not yet. I've kicked it around a few times putting a rear bar on it to see if I like it better with more rear roll stiffness, but it's a complete nightmare trying to figure out some bar shape/configuration that will work on my car. The combination of narrowed suspension, wide knuckle pieces, and stock C3 frame width/shape just doesn't leave much room to snake the bar arms through and also allow some end link lengths.
Hopefully one of these times I'll have an a-ha moment and find a workable solution.
Old Sep 18, 2016 | 11:55 PM
Gale Banks 80'
I'm currently looking for that A-Ha moment. The C4 Bar has way to long radius bends. The C3 bar is much better but I think a very special Spring Bolt will need to be created to attach the Sway Bar.
Old Sep 19, 2016 | 11:04 AM
gkull's Avatar
gkull
I use 1 X 2 inch rectangle tube to space my bar down from the frame to make my sway parallel to the ground when I have weight on the tires.
The attachment point to the HD trailing arms and spring ends are all from VB&P. But I had to bend the bar in the middle to get a perfect 90 degree attachment.
Back when I had Koni rear shocks and the rear tires are off the ground. 3/4 inch bar, but the spring end links make it not come into play until you have a certain amount of vertical wheel movement. So it is like no bar and then body roll can bring it in
To autocross spring choice?
