I know this has probably been rehashed a hundred times. I'm trying to ID my 4-speed as close or wide ratio. '77 L82, 3.70 rear ('OC' marked on the diff). No painted letters on the trans. No metal tag. Found the vertical marking on the left rear of the trans near the cover. I don't have a date code with 'A', 'B' or 'C' There is only the last 7 digits of my VIN# and 'WM7' and '62'. Anybody seen anything like that? Anyone know what it means?
The metal ID tags on the Muncies ended in 72 for the corvette. Probably because the M22 was no longer an option on the 73's. Just two choices for manual trannys. M21 & M20.
Regards,
Jimmy
Since my transmission case markings don’t seem to provide any indication as to whether it’s close or wide ratio, figured it out myself. Easily done once you think about it. In both the close and wide ratio gearing, the % difference is pretty much the same between 1st and 2nd and 2nd and 3rd gears. The difference in gearing is between 3rd and 4th gears.
Close ratio:
2.43 to 1.61 34% (1st to 2nd)
1.61 to 1.23 24% (2nd to 3rd)
1.23 to 1.00 19% (3rd to 4th)
Wide ratio:
2.64 to 1.75 34% (1st to 2nd)
1.75 to 1.34 23% (2nd to 3rd)
1.34 to 1.00 25% (3rd to 4th)
Just picked a speed and noted the RPM for both 3rd and 4th gears. My RPM at 30 MPH is:
3rd gear 1850 RPM
4th gear 1500 RPM
A difference of 19%, indicating it’s the close ratio trans.
