70 frame
Old Sep 14, 2016 | 11:30 AM
colo69's Avatar
colo69
Default 70 frame
What would you have to change or modify to put a 73 frame under a 70 car?
Old Sep 14, 2016 | 11:35 AM
Alan 71's Avatar
Alan 71
Hi c,
You can use the 73 frame.
The difference will be in the height of the body mounts…the 73 frame is set up for rubber body mount bushings while the 68-72 frames used an aluminum 'puck' as a bushing. The mounts were lowered about 3/8" for 73. This won't be a problem.
Remember that 4-speed frames had the transmission crossmember welded in place but the automatic frames crossmember was bolted in place.
Regards,
Alan
Check this link.
http://www.71corvette.com/frames.html
Old Sep 14, 2016 | 01:31 PM
colo69's Avatar
colo69
Originally Posted by Alan 71
Hi c,
The difference will be in the height of the body mounts…the 73 frame is set up for rubber body mont bushings while the 68-72 frames used an aluminum 'puck' as a bushing. The mounts were lowered about 3/8" for 73. This won't be a problem.
Regards,
Alan
Check this link.
Thanks, Alan
So would you just use the rubber body mounts for a 73 or would you lower the brackets or shim and use aluminum pucks?
Also would the front bumper brackets be a problem?
Old Sep 14, 2016 | 03:03 PM
Alan 71's Avatar
Alan 71
Hi c,
I'm always interested in originality so I'd figure out a way to use the aluminum 'pucks'. I don't think I'd go through the work of changing all 8 mounts though. I'd look to see if I could make it appear to have what a person would see when looking at a 70 frame.
Many folks would say that's silly because the rubber bushing gives a more cushioned ride. So they'd install the rubber bushings and be done with it.
Regards,
Alan
Old Sep 14, 2016 | 03:12 PM
colo69's Avatar
colo69
Hi c,
Regards,
Alan
So,Alan
I was just wondering if the rubber bushings gave a better ride then why change out the bushings from the c2 that had the bushings to the early c3 didn't! The bushings clearly looked worn on my c2.
Old Sep 14, 2016 | 03:52 PM
Alan 71's Avatar
Alan 71
Hi c,
There's got to be some 'softer' ride with the rubber mounts.
They both deteriorate though… the aluminum oxidize and the rubber deteriorates.
As I said it really depends on how accurate you want to be as to which you chose.
Regards,
Alan
Old Sep 15, 2016 | 11:05 AM
colo69's Avatar
colo69
Hi, Alan
i found a 79 frame ! I saw the link and i was a little confused about using the 79 frame. So if i just cut off the rear bumper support and weld on my old one, and the lower body mounts, should the 79 frame work?
Check this link.
http://www.71corvette.com/frames.html[/QUOTE]
Old Sep 15, 2016 | 03:23 PM
Alan 71's Avatar
Alan 71
Hi C,
It looks to me like the rear 12-18" of each frame rail, along with the tank mount bracket, changed along with the rear crossmember.
I'm unsure how the front frame extensions changed as the rubber bumpe design progressed.
What caliber of a 70 are you working on. I ask only because on certain cars a modified frame might raise some eyebrows.
Regards,
Alan
Old Sep 16, 2016 | 06:58 PM
DUB's Avatar
DUB
I agree...it is NOT just the rear bumper support on the frame.
Not to mention that the brake proportion valve for a 1979 has a bracket welded to the frame. And not knowing what type of brake system...it may require you drilling some holes for your brake lines to be secured.
DUB
Old Sep 17, 2016 | 09:51 AM
colo69's Avatar
colo69
DUB
Thanks again, you are the man!!!!
To 70 frame
