Replacing axle stubs for BB?
Old Sep 14, 2002 | 05:43 PM
467-Ratman's Avatar
467-Ratman
Default Replacing axle stubs for BB?
When we converted to the BB last winter, the only thing I have not replaced are the axle stubs that go into the differential. I have found that BB cars had heavy duty ones and I still have the ones that came with my SB. Any suggestions on where to get them and do I really need to do it?
Old Sep 14, 2002 | 05:48 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Replacing axle stubs for BB? (467-Ratman)
I just sold a set of big block ones. I have aftermarket forged ones. I am a big believer in over building things. Stub axles are one of the weak links in the rear, and you have a pretty stout big block. If one breaks you are going to wish you had good ones.
Old Sep 14, 2002 | 06:36 PM
redvetracr's Avatar
redvetracr
Tom,
The yokes themselves are the same the difference is what holds the u-joint, the BB yokes are threaded to accept a bolt which holds a cast cap instead of the strap as used on the SB yoke. I have a NOS/GM in the package set of caps for sale if anyone is interested. ...redvetracr
PS: a friend of mine bought a set of those "fancy" trick yokes a couple of years ago, he snapped one right away.
[Modified by redvetracr, 4:40 PM 9/14/2002]
Old Sep 14, 2002 | 08:30 PM
467-Ratman's Avatar
467-Ratman
Default Re: Replacing axle stubs for BB? (redvetracr)
Thanks for the info redvetracr, they must be the heavy duty ones then? How much do you want for them? Thanks,
To Replacing axle stubs for BB?
