roller cam break in
Break in oil? If there is a good assembly lube used on the motor, not really. But, how much is a container of break in lube? How much is a new cam?
Fresh total rebuilds with a roller cam require a breakin and breakin oil just like any other new engine would demand.Personally, I would do a 20-30 minute breakin in procedure with breakin oil with a roller cam only. Why wouldn't you? Plenty of documentation from very credible sources suggesting the same. Its easy and a no brainer....
The beauty of the roller cam is you don't have to break in the cam lobe with the roller lifter so you can take it out as soon as it's running and do the procedure for breaking in the rings
Remember, rings are forced out against the cylinder walls by combustion pressure behind them in their backspace between the ID of the ring and the piston's ring groove back wall. That's how rings are designed.
If an engine has any trouble breaking-in, it was not built correctly. Period.
Break-In oils are the absolute worst oils on the market, because they provide dangerously little wear protection. Many engines have been ruined during break-in because of people using those worthless oils. And the people involved want to blame everything in the world other than the oil. They just don't know, what they don't know.
540 RAT
Mechanical Engineer
U.S. Patent Holder (Mechanical device designed for Military Jet Aircraft)
Member SAE (Society of Automotive Engineers)
Member ASME (American Society of Mechanical Engineers)
Lifelong Gear Head, Mechanic, Hotrodder, Drag Racer, and Engine Builder
For the truth about motor oil wear protection, that is not just opinion or theory, see my "TECH FACTS, NOT MYTHS" Blog, which now has over 220,000 views worldwide. You can see the Blog and my entire 190 motor oil “Wear Protection Ranking List”, which is "proven" by the Physics and Chemistry involved, and EXACTLY matches real world severe over-heating experience, real world Track experience, real world flat tappet break-in experience, and real world High Performance Street experience (test data validation doesn’t get any better than this), along with additional motor oil tech FACTS, by going to the Blog link below. Methodology, proof, facts, data, Industry endorsements, real world validation, etc, are all included in the Blog. See for yourself, the engine you save may be your own.
http://540ratblog.wordpress.com/
You dont theres too much BS on the internet that will convince some these are made of paper mache
Someone better call GM and tell them they dont know what they are talking about cause some guys blog says different.
