29199 diverter valve
Old Sep 19, 2016 | 10:05 PM
bucharli's Avatar
bucharli
Default 29199 diverter valve
should it be in the closed position when there is no vacuum or open? how much vacuum to close it.
Old Sep 20, 2016 | 07:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I give up. What's a 29199 diverter valve?
Old Sep 20, 2016 | 09:11 AM
Alan 71's Avatar
Alan 71
Hi b,
I recognize the number as an A.I.R. diverter valve.
The technical information I have mentions the vacuum signal required to overcome the spring force opposing the diaphragm action. It's purpose is to prevent a backfire. But it doesn't specify the amount of the vacuum required just that the high vacuum signal is sent from a connection just below the throttle plate in the carburetor.
Regards,
Alan
Old Sep 20, 2016 | 09:45 AM
Tooch1's Avatar
Tooch1
Hi Mike,
Here is a picture the 29199 Diverter Valve on my 73.
Jim
Old Sep 20, 2016 | 09:48 AM
bucharli's Avatar
bucharli
ok. so i cant really test its function off the car. just picked one up and wanted to test it since i wont be near the car for another 6 months. the one i have is sitting in the open position in the box.
Old Sep 20, 2016 | 10:26 AM
Alan 71's Avatar
Alan 71
Hi b,
I THNK you CAN test it off the car. Jim might know for sure.
It seems to me you could hook a small hose from the nipple on the side of the diaphragm 'can' to a mity-vac type vacuum pump and look through the inlet opening to see if the diaphragm assembly spool is being moved by the vacuum.
Maybe?
Regards,
Alan
Here?
Old Sep 20, 2016 | 10:28 AM
bucharli's Avatar
bucharli
thanks alan. doesnt move. even hooked it up to manifold vacuum on my ford.
Old Sep 20, 2016 | 10:35 AM
bucharli's Avatar
bucharli
does anyone rebuild these things to work or just looks?
Old Sep 20, 2016 | 11:10 AM
Alan 71's Avatar
Alan 71
Hi b,
A good place to begin is Bill Hodel, 330-832-0871.
Regards,
Alan
Old Sep 20, 2016 | 07:37 PM
Tooch1's Avatar
Tooch1
Hi b,
You could also try Jeff Ashen in Florida. His email is pacecarjeff@bellsouth.net. He sells these rebuilt. Be prepared to pay big bucks for this one. It's the tough one to find. He would also take yours in on trade as a core. He sells on eBay as pacecarjeff.
Here's a pic of one he has for sale now at around $339.
I had my mechanic install mine when he reinstalled my intake and quadrajet for judging. Finding that 21299 was the hardest part to obtain when restoring my engine. Lucky you found one in any condition. Most guys just block all the hoses and just have them on for appearance for judging.
Regards,
Jimmy
Old Sep 21, 2016 | 10:20 AM
bucharli's Avatar
bucharli
Originally Posted by Tooch1
Hi b,
Regards,
Jimmy
thats who i bought it from. he said its guaranteed. but i wont be installing it till feb/mar. car is at my house in florida
Old Sep 21, 2016 | 10:33 AM
bucharli's Avatar
bucharli
and i really do want functional equipment on my car. i consider myself a mechanic so it will function as designed!
Old Aug 14, 2019 | 07:00 PM
Pacecarjeff's Avatar
Pacecarjeff
Non functioning is really the way to go. The functional pump eats Horsepower like an A/C compressor, and really does not do anything for the environment.
The pump forces air into the exhaust manifolds which lowers the "parts per million" of carbon exiting through the rear pipes.
In reality it is not cleaning the air.
Imagine for a minute you are going to dump a bucket of sewage into a lake,
But rather then pouring directly in by itself, you pour your sewage into a larger bucket of clean water and dump that bucket with both combined....
You are still pouring the exact same amount of contaminants, but you mix it first so it appears cleaner when it hits the lakes surface. lol
That is what the early A.I.R. did. All for show - - - It's still the same stuff.
here are a few instruction guides to make your system non functioning - but still appear to be 100% correct and functioning.
And you will gain 25 +/- Horsepower too.
http://www.broachbuster.com/id50.htm
http://www.broachbuster.com/id64.htm
Hope this helps... Jeff
To 29199 diverter valve
