trick flow heads ?
Old Sep 14, 2002 | 09:41 PM
LT1driver's Avatar
LT1driver
Default trick flow heads ?
what is the difference between the twisted wedge heads and the 23 degree heads. :confused:
Old Sep 15, 2002 | 02:16 AM
fauxrs's Avatar
fauxrs
Default Re: trick flow heads ? (LT1driver)
The twisted wedge heads place the intake and exhaust valves at different angles to help unshroud them -very easy to spot - 23 degree heads have all the valves in a row just like normal heads - at a 23 degree angle to (the vertical????)
Others should be able to add more detail.
Old Sep 15, 2002 | 05:06 PM
LT1driver's Avatar
LT1driver
Default Re: trick flow heads ? (fauxrs)
OK, now question is can I use them with my domed pistons? Thanks. :cheers:
Old Sep 15, 2002 | 05:13 PM
Ryan77's Avatar
Ryan77
I'm planning on running the 64cc 23 degree Trick Flows when I stroke my motor to a 383
Old Sep 15, 2002 | 05:29 PM
fauxrs's Avatar
fauxrs
I dont think so - back when thney first came out I seem to remember reading that trick flow heads should be run with flat tops or dished pistons only - your domed pistons are certainly designed for the standard valve location of a typical chevy and not the rotated locations of the trick flow heads.
Old Sep 16, 2002 | 02:18 AM
LT1driver's Avatar
LT1driver
Dang, wanted the most power, guess standard 23* will have to do, anything is better than 70 model heads. :cheers:
To trick flow heads ?
