Carb Question - High Idle
Old Sep 14, 2002 | 09:43 PM
Jack71's Avatar
Jack71
Default Carb Question - High Idle
I have a Holley Street Avenger w/ Electric choke that is idling around 1500rpm. The weird thing is I just put on a new exhaust and this problem hits.
The choke doesn't appear to closed. So before I just adjust the idle screw, could these symptoms be caused by any other carb problems?
These carbs are a pain, because there is really no literature specifically for these models.
Thanks in advance...
Jack
Old Sep 15, 2002 | 12:15 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Carb Question - High Idle (74jack)
Maybe youve pulled some vac lines in progress.That would give you a high idle.. :cheers:
