Steering
Old Sep 24, 2016 | 08:12 PM
bobmg's Avatar
bobmg
Cruising
Default Steering
Put in new control valve, adjusted, bled etc. Takes a lot of effort to turn wheel. Seems like more than should be. Can the control valve cause this or should I look deeper?
Old Sep 25, 2016 | 04:23 PM
7T1vette's Avatar
7T1vette
The P/S pump makes the hydraulic pressure needed to operate the system. The control valve uses that pressure to make the system work. If your P/S system worked OK before your [original] control valve bit the dust, it's most likely that the 'new' control valve is defective. Very common among the [junk] rebuild parts we buy these days.
