SPARK PLUG/WIRE REPLACEMENT QUESTIONS
Any advice on what if anything must be removed to facilitate access to the required plugs/routing on my ‘81? For example, some CF responses have mentioned removal of heat shields, exhaust manifolds, starter motors, etc. If the job requires most or all of these, I’ll have to enlist outside help. Any other tips to get it done efficiently will be appreciated.
I don’t own any of the repair manuals and am looking for a clear, correct routing diagram. Are there any electronic image files available out there? If not, any suggestions on ONE repair manual purchase?
A “mechanic” replaced plugs/wires on my car three years ago and opted to circumvent the motor mounts. I would like to do it myself this time, and correctly if possible. I’ve had recurring motor mount breakage - the third go-round the lone culprit was replaced with the lockable variety. Will this type of mount allow the same spark plug wire access as the original type?
I’ve had some oil leakage buildup on and below the engine, and some of these areas are difficult to access. Is there a spray-on product on the market that will dissolve this gunk above and below without damaging the non-metal parts?
While I’m up to my elbows in grease, does it pay to remove my blown a/c compressor (til next spring’s replacement) and the broken smog pump (til my next inspection test)? These suckers are big, in the way and ain’t doin’ nothin’. The smog pump belt was recently removed. With the a/c belt gone as well, would my water pump have enough redundancy to run reliably?
Finally, thanks to the authors of recent postings on removing/painting rear and front window trim and repairing t-roofs. When you’re able to nail the inevitable little sh*! yourself, the inevitable big sh*! is much easier to accept.
[Modified by Runner81, 5:40 AM 9/15/2002]
It was definitely a plus to be able to work on the car from underneath, so get it up on jack stands or ramps (although the ramps might be in the way themselves).
There are engine degreasers (GUNK is a big name, but other manufacturers have their own variants out too). I'd shoot the engine frome above & below.
I'd also worry about what else the mechanic who "replaced plugs/wires on my car three years ago and opted to circumvent the motor mounts" did while he was in there. You really need to get an '81 diagram of the wires & shielding. It would have been very easy for him to pull that stuff off to get it out of his way and NOT put it back on (hopefully that didn't happen).
I also have gotten into the habit of using dielectric grease on electrical contacts and anti-sieze on parts that I don't want rusting together. So, I used the dielectric on the sparkplug & dist tips and the anti-sieze on the plugs.
Just some thoughts. It took me a long time with a lot of trips under the car & back up, but it's not a horrible job and it sure is nice to have it complete and done right.
Good Luck.
For the oil & grease, Gunk is OK but leaves a white residue that needs a lot of water to wash off. I prefer Jizer or Hyperclean as they wash off a lot quicker. Careful where you squirt the water (I wished that I'd cleaned up my block b4 fitting the plug leads!).
My Vette has no air pump & I pulled off the a/c compressor last winter. The water pump works fine.
I got a workshop manual from Ecklers for the '81 ($70?) & it's better than my other 3 Vette manuals put together (especially on the electrics). Somewhere I've got a pic of the plug wire routing, but it's hard to read & after scanning it would probably be useless (but I could try if nobody else comes up with one).
:cheers:
