Conversion to Fuel Injection questions
Nicest tank is the Rock Valley custom stainless steel. Many internal baffles, internal EFI pump, bolts up like stock. But it will run you over $1K.
For a little over 1/2 that they offer a modified stock tank.
As for which EFI system is the best that's impossible to say as no one on here has bought every single system on the market and compared them. I'm running the Holley HP and think it's a very capable system.
If you want you can also expand it to support ignition control later, too.
https://www.holley.com/products/fuel.../parts/550-510
For $999 it's a steal, but obviously no one has actually used one yet.
WAY less popular and quite a bit more expensive, but I really like the Edelbrock E-street 2 EFI system, too. -You communicate with it over bluetooth using any Android phone or tablet- you can even use an Android Auto stereo with touch screen to view and control your EFI then; being able to just use a table and an app over bluetooth seems way more modern than using a wired GPS-style touch screen, IMHO.
Adam
C5 FPR = C5 Corvette fuel pressure regulator (and filter) :
https://www.summitracing.com/int/par...MobileSwitchNo
The advantage is that you don't have to use a 'normal' fuel pressure regulator in the engine bay and run a return line to the tank as the hard line is too small.
So from the fuel pump unit you have two lines going to the FPR, one feed and one return. (The hard lines you see in the picture I made myself).
The FPR has one outlet. From here I used a teflon braided pre crimped hose (straight end and a 180° end) to the 3/8 hard line. On the hardl line I used a Swagelok coupling 6An to 3/8 : http://www.swagelok.com/en/catalog/P...t=SS-600-6-6AN
With the tank out there's enough room to get a small tube cutter on the hard line and cut of the bubble.
The same coupling is used in the engine compartment with another pre crimped hose (90° end and a straight end). The hoses came from Pegasus racing. Very good quality and no fuel odor.
The bracket to support the FPR I had welded on (simple L shape)
The original fuel return line is capped of.
When the fuel tank is installed there's enough room in between the tank and the rear bulkhead to disconnect the fuel lines and replace the FPR. I had to do it as the unit I bought from tanks inc put out too much fuel pressure. The ones from WIX or Delco are more reliable.
Make sure the system you choose can handle 56 psi because that's the fixed output of the FPR.
I went for this setup as I don't want flexible fuel lines underneath the car nor a fuel pressure regulator in the engine bay.
Nick
Adam
Nick
