4 Speed Shifter
Old Sep 28, 2016 | 08:46 AM
clatgeo's Avatar
clatgeo
Default 4 Speed Shifter
The shifter on my M21 tranny is not smooth going into second gear. It takes a little more effort to get into second gear than the other gears.
Has anyone else had this problem?
Old Sep 28, 2016 | 08:53 AM
Capt Ken's Avatar
Capt Ken
Default Re
When I was having shifting issues, it turned out to be internal not the shifter. I don't think it calls for grease, but you could spray it first with some carb/brake cleaner as someone works the shifter to clean out any gunk, then follow up with some white grease to see if it makes any difference.
Old Sep 28, 2016 | 09:08 AM
Rodnok1's Avatar
Rodnok1
Usually points to an internal issue, syncros, forks for a start wear out . Disconnect the linkage and see if shifter moves freely. May need a going through first.
Old Sep 28, 2016 | 01:11 PM
clatgeo's Avatar
clatgeo
I have disconnected the shifter rods and it goes into second easily.
The shift levers have two holes, one for short throw and another for long throw.
Old Sep 28, 2016 | 02:05 PM
Scottd's Avatar
Scottd
Simple answer....yes. Thats EXACTLY what was going on with mine, as well as popping out of gear on heavy decel.
I had the transmission out 3 times and rebuilt it twice and still didnt fix the problem. I learned a lot and replaced everything on the inside
but it was still tough to get into 2nd and still popping out of gear, Then, on a whim, I replaced the side cover and fork detents (where the forks go through)
Problem solved!
So, like everyone else has said, check your linkage and pivots, make sure your shifter is lubed and properly assembled. If its still giving you problems, try the side cover. If that doesnt work.....its going to be your synchros and that means you get to learn how to tear apart a transmission just like I did!
Old Sep 28, 2016 | 06:36 PM
rebel542's Avatar
rebel542
Mine was doing that, jumping out of gear, and I ended replacing the sliders on both synchro's. I got them here at http://www.5speeds.com/newm22.html
Old Sep 28, 2016 | 08:56 PM
63split63's Avatar
63split63
Default Call 5speeds.com
If you call 5 speeds Paul will diagnose your problem for free and advise you on what parts you need . His parts are reasonably priced .
To 4 Speed Shifter
