Need help with AC
Old Sep 29, 2016 | 06:27 PM
sullyman56's Avatar
sullyman56
Default Need help with AC
I have a 68 that is lacking nearly all the AC components. The only parts that came with the car are the evaporator and POA valve. I see according to the AIM that the hoses that run from the compressor connect to these parts with clamps. I found a muffler setup and only lack the hoses, but they are available. The problem is that the 68 frame is long gone and mine is a 69 or later and accordingly has the 69 and later radiator support. I know that the brackets for the 68 are hard to come by so I suppose I'm stuck with a 69 and up condenser and dryer setup. So, I'd like to know if I should go with a 69 muffler/ compressor hose setup so everything lines up and since the hoses have fittings attached are they the same size as the ones already on the car? Thanks in advance.
Old Sep 30, 2016 | 03:27 PM
Tampa Jerry's Avatar
Tampa Jerry
Default A/c
I would call Classic Auto Air here in Tampa and ask them what parts you need to upgrade the system. My 68 has been upgraded to with a Sanden compressor as well as a modern dryer and blower and works well here in Tampa. Jerry
Old Sep 30, 2016 | 04:27 PM
sullyman56's Avatar
sullyman56
I figured it out. Thanks. Moderator please close this thread.
To Need help with AC
