Oil pan
Old Oct 8, 2016 | 12:54 PM
croaker's Avatar
croaker
Default Oil pan
Are the oil pans on our cars pretty much standard 350 issue or, are they vehicle specific?
Old Oct 8, 2016 | 01:07 PM
A88FXRS's Avatar
A88FXRS
somewhat specific as to options, engine, drain plug position and crossmember fit.
Old Oct 8, 2016 | 01:44 PM
jb78L-82's Avatar
jb78L-82
The L-82 oil pan on my 78 is different from the L-48 passenger car engine pan. I was looking to replace the L-82 OEM pan when I rebuilt the motor in 2014 and cannot find an L-82 pan with the drain plug on the drivers side but more importantly the internal baffles that prevent oil starvation on hard cornering and acceleration/braking. The OEM 78 L-82 pan is not offered in the aftermarket.....I reused the OEM L-82 pan after straightening the edges and repaint....all worked out.
Old Oct 8, 2016 | 01:58 PM
gbvette62's Avatar
gbvette62
Corvette pans are usually unique to Corvettes, but generally, all 63-79 Corvette pans are similar. The exceptions were the larger capacity pan (5 qt vs 4 qt) used on 63-65 solid lifter 327's and 70-72 LT-'s and the baffled pan found on late 70's L-82's.
80 and later 350's use a completely different pan, with the dipstick located on the right (passenger) side of the block.
Old Oct 8, 2016 | 02:17 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
You have to be careful with the early sbc oil pans as the front gasket clearance changed at least once and many of the passenger car pan are shaped differently along with the dip stick location change.
GMPP used to sell the Z28 oil pan with somewhat better baffling (not the best though), not sure if they still sell it now. Oil pans can get expensive but if you circuit track race you can't have a less than adequate pan or your motor will be short lived.
Hope this helped more than it confused you.
Old Oct 8, 2016 | 02:21 PM
croaker's Avatar
croaker
Glad I asked. I'm swapping engines in the future and, the next resident may get this ones pan.
Old Oct 8, 2016 | 02:25 PM
croaker's Avatar
croaker
Mine is a lowly L-48. What differences should I look for I wonder? 75 vintage . Replacement block I want to say same era
Old Oct 8, 2016 | 02:49 PM
jb78L-82's Avatar
jb78L-82
Any number of supporting and non supporting vendors should have a base L-48 oil pan....
Old Oct 8, 2016 | 02:55 PM
cardo0's Avatar
cardo0
For a '75 you want a driver's side dip stick. Be careful of cheap oil pans w/o any baffling.
For stock replacement w/baffling try RockAuto - <$50.
Old Oct 8, 2016 | 03:21 PM
jb78L-82's Avatar
jb78L-82
Cardo0 is right about the driver's side dipstick and rockauto offering the best price...no idea of quality....No, though, on the baffling from any of the vendors..base L-48's did not come with oil baffles, only the L-82 option:
http://www.ecklerscorvette.com/corve...1963-1979.html
http://www.rockauto.com/en/catalog/c...e,oil+pan,5562
Old Oct 9, 2016 | 08:56 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
My LT 1 pan is pretty dented up. I keep looking for a replacement but may end up trying to tap or roll the dents out myself.
To Oil pan
