is this the crank i need?
Old Sep 16, 2002 | 08:27 AM
OkeeGuy's Avatar
OkeeGuy
Default is this the crank i need?
as some of you already know i broke my crank in half...
is this the crank i should be buying? http://www.gmpartsdirect.com/perform...CATID=883.html
Old Sep 16, 2002 | 08:33 AM
Pete79L82's Avatar
Pete79L82
Default Re: is this the crank i need? (SIGNGUY)
That would be the crank that was used in all LT-1's and L-82's.
Old Sep 16, 2002 | 08:57 AM
Gordonm's Avatar
Gordonm
Default Re: is this the crank i need? (Pete79L82)
That is what is in my LT1. Will work no problem
Old Sep 16, 2002 | 09:11 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: is this the crank i need? (Gordonm)
is there something better?
wheres the best place to buy it?
Old Sep 16, 2002 | 09:47 AM
Gordonm's Avatar
Gordonm
Better there is always something better. I doubt you will break this. I have seen this crank run in circle track motors all day long. For a street driven car this is all you should need. Now if you want to go stroker there are other cranks out there, but they will cost more and then the block will need clearancing. Crower, Lunati are two cranks that come to my mind. There are others out there keep searching.
Old Sep 19, 2002 | 07:56 AM
OkeeGuy's Avatar
OkeeGuy
im seriously thinking of this kit which DOES include a crank...
although i will need rods...
any sugestions? http://www.northernautoparts.com/Pro...ctModelId=1674
also...which of these cams will give me the performance that i am looking for?
which is...
350+ HP with good bottom end tourqe...
i love that 0-60 like a rocket stuff!
a good daily driver in traffic and 200-300 mile weekend trips...
street friendly...interstate friendly
should i shoot for the 9.1 compression range?
[Modified by SIGNGUY, 6:58 AM 9/19/2002]
To is this the crank i need?
