My 72 LT-1, all stock with the exception of a Holley Street Avenger carb, used to idle at a steady 900 RPM, per specs. Now, after the engine is warm, the idle drops to down to be about 500 RPM when coming to a stop and then slowly climbs back to a slightly rough 850-900 RPM idle. It has also become harder to start when it is warm, almost like it is slightly flooded. However, there is no evidence of gas dripping into the carb after a hot shutdown. The car runs well other than the idle issue. Anyone have any ideas?
Check the EGR valve it opens when the engine gets to temp and if it is leaking vac that could cause the bad idle.Get the engine to temp so it starts running bad and take the vac line from the carb to the EGR temp sensor valve at the front of the engine and pull it off the carb. Put you're finger over the the carb port and see if the engine starts to idle right.
2016 C3 of Year Finalist
Did you drive it this summer in hot ambient air conditions with no problem?. Reason I ask is my 68 has a 72lt1 motor and I had a perculation problem in the spring as the outside air temp rose, my problem got worse. Wooden spacer, moving the gas line, using a fuel pressure regulator solved my problem.
Sparkiy77es assessment sounds like a good start otherwise. Either that or you got some bad gas and it dirtied your idle circuit in your carb. If the egr doesnt work try pulling the idle mixture screws and blowing low pressure air through the circuit. The edelbrock tech online suggested that in a vid on my carb. Shouldn't hurt yours
A '72 (any engine) does not have EGR. A drifting idle is usually an sign of a carburetor out of adjustment or in need of a cleaning. A cheap vacuum gauge is a very useful tool when it comes to collecting engine performance data. I suggest you get one since diagnosing a problem without data is just shooting in the dark.
Thanks for all of the suggestions. I actually have a vacuum gauge but didnt think it would be helpful in this instance since the problem occurred only under certain driving conditions and not when idling in the garage. I had fuel percolation issues with the original carb as well as other issues that could not be resolved which is why I run the Street Avenger.
While I had checked the fuel level on the primary side I had not on the secondary side and when I looked at that today I found it was quite high. I couldn't adjust it and had to change out the needle and seat. That appears to have fixed it. Thanks again for the help.
