74 rear end gearing
Old Oct 23, 2016 | 08:52 PM
vmsns007's Avatar
vmsns007
Default 74 rear end gearing
Driven gear is bad. I understand that to replace I need to know my rear end gearing and tire diameter. My tire diameter is stock but what is the factory gearing on my base engine 74? Any way to tell from differential markings although mine is unchanged from stock
Old Oct 23, 2016 | 10:27 PM
cobrachuck's Avatar
cobrachuck
Automatic or 4 speed car?
Stock rear gear for automatic is 3:08 I would need to search for a stick shift car.
Now the ratio numbers are found on the bottom of the rear end date codes as well.
My stock 75 L48 auto were
AW = 3:08
Good luck
Old Oct 23, 2016 | 10:32 PM
cobrachuck's Avatar
cobrachuck
Found it, from Vette.net. Sorry looks like I was mistaken,
Transmission
Automatic Manual
Type 3-Speed Automatic 4-Speed Manual
Gear Ratios
1st 2.48 2.52
2nd 1.48 1.88
3rd 1.00 1.46
4th NA 1.00
Reverse NA NA
Axle Ratio NA NA
Final Drive Ratio 2.73auto 3.55 manual
Old Oct 23, 2016 | 10:40 PM
vmsns007's Avatar
vmsns007
Thanks. Yes it's a 4 speed. Warner transmission I believe for a June 1974 car with base L 48 engine (198 HP).
So if I read this correctly my car is geared at 3.55?
Transmission
Automatic Manual
Gear Ratios
1st 2.48 2.52
2nd 1.48 1.88
3rd 1.00 1.46
4th NA 1.00
Reverse NA NA
Axle Ratio NA NA
Old Oct 24, 2016 | 07:09 AM
BKarol's Avatar
BKarol
This is from the gm heritage center. It appears that you could have a 3.36 which is std or the econ 3.08. Page 34 or 49 .
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
You might want to download this file for future reference.
Old Oct 24, 2016 | 09:38 AM
Grahamred70's Avatar
Grahamred70
Only way to be sure is jack up the back with both wheels off the ground, turn the road wheel one turn and count how many turns the drive shaft does, I think mine came with a 3.55 or 3.36 but when I checked it was a 4.56 so no wonder it felt like I was in 2nd gear all the time!!
I'm changing for a 3.36 over the winter along with a new clutch and a gearbox overhaul so should be a lot more civilised.
Graham
Old Oct 24, 2016 | 02:05 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
If you have the differential cover off or the differential out of car counting the teeth is a definite way to find it. FWIW my '74 L48 w/4sp had 3.36 gearing when I took them out. Chevy offered nearly all the ratios as an option so you would need your options/build sheet to know what came with your car.
Old Oct 25, 2016 | 02:51 AM
Richard Daugird's Avatar
Richard Daugird
Graham
^This^ Who knows what has been done to that car in forty years.
P.S. What ya gonna do with them 4.56???
Old Oct 25, 2016 | 04:59 AM
Grahamred70
Haven't thought about it but if anybody wants it I'll sell it, after all I'll never use it, could work well with one of those fancy 6 speed trans? It seems to be in good nick, doesn't whine or anything so should be worth good money to somebody.
Graham
Old Oct 25, 2016 | 12:48 PM
Richard Daugird
The shipping from Wales would be a killer.
To 74 rear end gearing
