Alternator not charging
Old Oct 25, 2016 | 07:30 PM
antoniov1's Avatar
antoniov1
Default Alternator not charging
Ok I'm getting fed up with this car if it's not one thing it's another thing! Now it's not charging. Now sure if it has even been charging since I've had it. Put a new battery since the battery was bad. Had the alternator checked and it was bad so put a new one. Checked the charging system today with a multi meter and it isn't charging! What do y'all suggest cause I'm lost now. It's on my 82. Here are my results. I was reeving it over 2500 rpm. I read on this forum it could be the warning/charging light? If y'all suggest that where is it located at?
Old Oct 25, 2016 | 07:37 PM
antoniov1's Avatar
antoniov1
Oh yea the red cable on the alternator has power and it is battery voltage
Old Oct 25, 2016 | 08:10 PM
antoniov1's Avatar
antoniov1
I'm guessing the battery light is the indicator light that needs to be on? Cause mine isn't on. The only light i see on is my e brake light.
Old Oct 25, 2016 | 10:11 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Would help your cause if you'd tell us what you're working on.
Old Oct 25, 2016 | 10:18 PM
antoniov1's Avatar
antoniov1
I said it was my 82 on my first post
Old Oct 25, 2016 | 10:56 PM
Hammerhead Fred
Sorry, missed that.
Agree, alt isn't putting out.
I'd pull it and have it checked.
Wouldn't be the first "new" alt that didn't work.
This thread may help you in your search for the gen light.
The gen light should come on when you turn the key to the on position.
If not it's likely burnt out.
Old Oct 26, 2016 | 03:18 PM
antoniov1's Avatar
antoniov1
Ok well I got the battery light working now except it seems to be flashing it stays on for like 6-7 seconds then turns off for like 10-15 secs and repeats the process what could that mean? My manual doesn't mention anything about a flashing batt light
Old Oct 26, 2016 | 05:54 PM
shok's Avatar
shok
Originally Posted by Hammerhead Fred
Sorry, missed that.
+1 on a new alt that does not work. Bought a new one a week or so ago and asked the guy to put it on the tester before I paid. Sure enough it was dead, luckily there was another on the shelf which tested okay.
Old Oct 26, 2016 | 06:14 PM
theandies's Avatar
theandies
You said this is on an '82. That almost sounds to me that the crude computer in those cars is telling you something. Is it a code of some sort?
Old Oct 26, 2016 | 10:58 PM
Hammerhead Fred
Good time then to check the Alt output voltage and see if it is cycling between battery voltage (light on) and Alt output @+14v (light out).
Fresh/good battery should be @13.8v but your earlier post was closer to 12v likely due to low/no charge coming from the Alt charging circuit.
Cycling could be due to bad Alt or loose belt or excessive load - are there alot of aftermarket electronics?
Old Oct 28, 2016 | 11:04 AM
lionelhutz's Avatar
lionelhutz
On the 2-pin connector:
Check for damaged or broken wires.
Check for worn out connectors.
Terminal 1 should be a brown wire. When you ground it the generator light should come on.
Terminal 2 should be a heavier red wire. It should have battery voltage at all times.
Old Oct 28, 2016 | 06:55 PM
DUB's Avatar
DUB
When you turn your ignition key on....does your 'CHECK ENGINE" light light up??? It should be on the right side of you gauge cluster.
DUB
To Alternator not charging
