Clutch problems Diagnosed - Warning - Large images
These are good size images so dial up users beware.
The first shot is the car up in the air and ready to begin - well actually I had already begun - as evidenced by the driveshaft laying on the floor. I dont know why the focus is off :confused:
You will notice I'm using 6 jackstands - the front two are there primarily to prevent all that cantilevered load on the frame - they are placed under the a-arms and carry only a very small portion of the load. You can also see my H-pipe in the foreground - this pipe occurs about 6" beyond the collector flange and goes underneath the transmission - it is very easy to remove and doesnt impede my ground clearance.
This is the working surface of the flywheel - it looks horrid but is smooth to the touch - I dont like the looks of the radial lines around the center section and am planning on replacing this item.
I will accept opinions on this matter - judging from the photo would you replace this item?
The pressure plate looks almost the same as the flywheel as evidenced in this photo. It's difficult to tell in this image but if you look closely at the diaphragm fingers from about 10 oclock to 2 oclock you will notice that they are not touching the ground like the others. This is the area where the problem must be - while in the car it was obvious that the throw-out bearing was not touching all the fingers as it should.
I will start ordering parts tommorrow for this. and am looking forward to comments on the flywheel.
[Modified by fauxrs, 6:25 PM 9/16/2002]
Stephan
Stephan
Also I have updated my homepage significantly - the engine section specifically - you can get to it through the link in the signature - or bypass the index.html by going here http://earchitect.50megs.com/corvett...ce_and_men.htm
[Modified by fauxrs, 8:58 PM 9/16/2002]
But if you want to upgrade to a lighter flywheel, it's a great idea. IMO, lighter flywheel (15lbs) are way better than the regular ones (35lbs) . I have experience it with an aluminium flywheel (14lbs) and it really work. Less weight to rotate equal faster acceleration. In a small block as you want to built, I say go for it.
Stephan
Another question. Centerforce makes the following statement in their FAQ "THEREFORE THE FLYWHEEL SHOULD ALWAYS BE PROPERLY RESURFACED OR REPLACED TO ASSURE GOOD CLUTCH PERFORMANCE. RESURFACING MUST BE PERFORMED ON A QUALIFIED FLYWHEEL GRINDING MACHINE. CENTERFORCE DOES NOT RECOMMEND RESURFACING FLYWHEELS ON A LATHE OR A BLANCHARD GRINDER"
their caps not mine :D
I dont really know the difference - is this peice of equipment common at machine shops?
Most machine shops actually don't have a flywheel machine. You have to look around until you find one. I've had the most luck with the independent mom & pop autoparts places.
Hans
