speedometer odometer stopped workin
Old Oct 29, 2016 | 08:36 AM
Blondie - C3's Avatar
Blondie - C3
Default speedometer odometer stopped workin
81 stock engine. Everything was working fine. Then the cruise stated being erratic. So i didn't use that. Then a few months after that the speedometer stated jumping around between 5 and 20 mph. After about two months the speedometer stopped working all together along with the odometer. what would be the order of debugging this problem?
Old Oct 29, 2016 | 09:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Blondie - C3
...what would be the order of debugging this problem?...
Cruise control transducer.
Old Oct 29, 2016 | 05:51 PM
SwampeastMike's Avatar
SwampeastMike
My order of debugging would be:
1) Lower speedometer cable that runs between the transmission and the cruise control transducer.
2) Upper speedometer cable that runs between the cruise control transducer and the speedometer.
3) If both cables are fine the transducer is defective.
I'm fairly certain that the two cables have direct gear connection within the transducer thus making speedometer operation failsafe in the event that the vacuum portion of the transducer fails. Had those direct gears failed you would have lost both cruise and speedometer at the same time. A failing cable on the other hand could easily cause erratic cruise operation, then erratic speedometer and no speedometer when it broke.
Old Feb 12, 2017 | 08:55 PM
Blondie - C3
Well she's coming out of storage soon. It was a mild winter. Wish I hadn't buttoned her up so tight :/ so it's time to tackle this speedometer issue. I was thinking of by-passing the transducer and foregoing the cruise. One cable $40. So does anyone have a link to good instructions on pulling out the old cables and installing just the one?
Old Feb 13, 2017 | 08:25 AM
drwet's Avatar
drwet
From the firewall to the transmission is easy. The hard part is under the dash. You will need to remove the HVAC duct on the drivers side for sure. IIRC you may find it is easier if you drop the steering column. I have done a few jobs under there and I usually drop the steering as a matter of routine. Its not that hard and it makes working under there much easier.
Old Feb 13, 2017 | 07:54 PM
Blondie - C3
Thanks. Do you have any links to how to drop the steering column or a video?
To speedometer odometer stopped workin
