Valve tip's destroyed - WTH??
Fast-forward to last night when I pulled the remainder of the rockers and found much more serious damage on all of the exhaust valves. What could be causing this kind of damage? Heat, improper pre-load, poor lubrication, crap valves? Surprisingly the roller tips are still in mint condition. Hard to believe this was caused by bad geometry alone.... Any thoughts??
Looks to me like really cheap valves and you are going to have to replace all of them. Make sure you use valve stem caps on the new valves and check the geometry of the valve train real good.
Now if the rocker tip completely slid off the valve tip and back on again that could explain it also.
My sympathies here but in my opinion someone who assembled an engine/valve train like that is not an engine builder but a wannabe engine assembler. Someone got awful lazy leaving you an engine like that or else they are incompetent building engines.
Pull the heads, replace the valves, springs, rockers, p-rods and have the valve guides checked. I'm guessing the valve guides are trashed.
Again my sympathies here.
Thanks everybody
Thx cardo0, I'm going to shortcut my path to sanity and just buy the AFR195's and ditch the ProComps. I won't call out the builders name here, but instead just que up my reply to the previous post. Get what ya pay for. Pretty sure you are right about the rollers slapping the valve tips and causing all this damage......
, I got what I paid for, a ~$4k for a 420HP crate motor made of questionable components...?..!.
Well this forum is swimming with non-supporting vendors that malinger here looking to sell you a great deal on their very good high performance part
. You haven't told us who but I have a short list of guesses. Yah know if they solicited you by PM -as I suspect - the only way the moderators/supervision will know is if you tell them. You really need to mention this to someone as it will spare others the same pain. I dont know what you have to lose now?You are an impressive enthusiast as we can read all the work you have done to your car. It's a shame the guys with the most passion for their car are preyed on the most. I can remember American Racing AR engines selling crap motors here until they eventually disappeared. Then there was blockman selling high end aftermarket blocks but well overpriced - he faded out also.
I think there are at least 3 names here that would sell you a motor like that. Only 1 owns a corvette but they all malinger here. I would like to at least know if they solicited you by PM.
Well I can respect your privacy.
Good luck with your new heads.
My suggestion is give the builder the opportunity to make it right. If they don't, please do share facts and save others from your headaches. Don't call them names or question the lack of genetic diversity in their lineage, or their meth use, but share the hard facts. They can't do anything to you legally without proving your facts wrong.
It could be the tip rolling off the edge, or it could be just crappy metal in the valve deforming and spalling off.
Procomp is bottom dollar crappy chinese hardware. I have their 8 stack intake. It took a bit of work to make it into a usable piece of hardware, but it's just an aluminum casting that is under no stress. I would never trust them for things under real stress like crank, rods, any critical moving fastener or any piece of the valve train. God forbid a flywheel begging to explode at 6000 RPM severing my legs. The heads may be salvageable with good valves, springs, retainers, guides and maybe even seats, but by the time you've done that, you might as well buy a new set of trick flow, edelbrock or afr's. Or at least a set of blueprint heads. They cast and make their own. So far I'm happy with my Blueprint 383. I have about 1000 miles, no oil consumption and it still looks like loose honey.
I emailed the builder today with pictures and data on what I found when I pulled the valve covers, including the fact that the pushrods were too long and the geometry was terrible. Regardless of their reply, I will share it along with the builders name. As you said, I have nothing to lose, and if they step-up and make it right they deserve to be recognized as a company that will do just that. Doesn't make the build quality acceptable, but at least they would stand behind what they put together. Who knows, maybe it was the builders last day when he put together my motor and he just didn't care. Doesn't make the company or the rest of the crew less legit... If they don't step up, I absolutely want to save others from going through this. My suggestion is give the builder the opportunity to make it right. If they don't, please do share facts and save others from your headaches. Don't call them names or question the lack of genetic diversity in their lineage, or their meth use, but share the hard facts. They can't do anything to you legally without proving your facts wrong.
Thanks for all the input guys.
