Static Compression Ratio Seems High?
Old Oct 31, 2016 | 04:35 PM
Shdggsdv's Avatar
Shdggsdv
Default Static Compression Ratio Seems High?
So I'm rebuilding the top end of my fairly stock (1990s Chevy pickup engine) bored 350 (355) and I decided to calculate my static compression ratio
I'm getting a readout that seems much higher than I'd expect from my engine. Math is telling me I'm getting 10.68:1
I have flat top pistons with insignificant valve relief so I measured all this as follows:
Bore: 4.030
Stroke: 3.48
Gasket Thickness: 0.028 (GM Composition gasket)
Deck Height: .025
Piston top volume: 0.00cc
Combustion Chamber: 64cc (Promaxx Aluminum heads)
What did I measure wrong, or am I really getting that high of a compression?
_____________
This engine is being fitted with a Comp xe274H .49 lift 274/280 duration cam and 1.6 roller rockers alongside a Promaxx 2180 aluminum 64cc combustion/190cc intake cylinder heads
Old Oct 31, 2016 | 05:31 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Typically those pistons have maybe a 5cc or so volume in the valve notches..so that has to be input as a negative number. If using the .028 gasket...otherwise you're pretty close. With a .040 gasket and 5 cc piston volume I'm getting around 9.9 or so.
JIM
Old Oct 31, 2016 | 05:49 PM
ddawson's Avatar
ddawson
I used this one http://www.csgnetwork.com/compcalc.html
Includes things like the gasket bore which effects it too.
It matched what the machine shop come up with too when they had all the parts in hand.
Old Oct 31, 2016 | 06:14 PM
REELAV8R's Avatar
REELAV8R
Like Jim said probably 5cc pistons. You could cc them in the block to find out exactly. The heads can also be cc'd. If they are "as cast" heads, their volume may vary to some degree from advertised volume.
I get 10.0 if 5 cc pistons are considered with a 4.1 bore gasket.
Old Oct 31, 2016 | 06:17 PM
Shdggsdv's Avatar
Shdggsdv
JIM
So with that correction I've got 10.07:1
Still a lot higher than I expected. I was assuming 9:1 would be like the tip of what I might end up with being a fairly shitty stock engine
Thanks for the help
Old Oct 31, 2016 | 06:44 PM
Bronze85's Avatar
Bronze85
Thanks for the help
Did you put it as +.025 deck height, I would think it should be 0 or less?
Old Nov 2, 2016 | 01:37 PM
Shdggsdv's Avatar
Shdggsdv
I did a bit of research on the deck height of a bone stock 350 and I came up with +.025
Old Nov 2, 2016 | 01:54 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Not acceptable as a number to input......most I have ever seen after 1985 or so come in about .015-.016......
Given these number using a Fel pro 1003 gasket (4.166x.041) you get this:
Which should be fine with those heads......your .025 deck number will make it even lower.......why are you using the .028 gasket....I believe it is a GM part.....but still.....
Jebby
Old Nov 2, 2016 | 02:06 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Jebby
Hmm...
Is 0.025" acceptable for older blocks? When I was researching my 79 L82, I also came across the 0.025" deck height #...
Adam
Old Nov 2, 2016 | 02:29 PM
69autoXr's Avatar
69autoXr
I found the same when putting a together a spreadsheet to calculate compression.
Why do you say that? Do you mean the calculator will not take it?
Old Nov 2, 2016 | 02:32 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by NewbVetteGuy
Hmm...
Adam
I am saying that if you do not measure it......you do not know.
The only .025 I have ever seen is in a 69' truck motor I tore apart...in fact it was like .030 if I remember......
The last 5 or so 350's (even my 406) were at .014-.016.....
Do not take my word for it......and what does it matter for calculations sake....? Use the big number and know the worst case scenario......
I have never built an engine without zero decking the assembly....the increase in compression is gladly offset by having proper quench.
Jebby
Old Nov 2, 2016 | 02:35 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No...I am just saying it is not realistic as far as the ones I have tore apart......you are just guessing......
Jebby
Old Nov 2, 2016 | 02:36 PM
427Hotrod's Avatar
427Hotrod
Older engines are routinely .018-.025 maybe in the hole. Mid 80's 302 Fords and many Mopar small blocks used POSITIVE deck heights where pistons are above the deck. My 555" has the pistons .009" out of the hole.
Also have to look at replacement pistons. Many are made "short" to allow for block decking and end up as much as .040" down in the hole..and then folks uses a .040-.050 gasket and end up with zilch for compression.
Only way to know for sure is to measure it.
JIM
Old Nov 2, 2016 | 02:41 PM
Shdggsdv's Avatar
Shdggsdv
Jebby
To be honest I'm pretty new to this. I'd originally assumed that my engine wouldn't be making much compression due to it's stock nature even with 64cc heads so I chose a gasket that would raise it as much as possible without damaging the mounting surface of the heads. Also, my engine was rebuilt at one point and was bored over. Just went out and measured with a caliper. Measured 4.045
Using that, the head gasket I have currently lying around, and your deck clearance; I'm getting almost 11.75:1 which seems WAY too high
Edit: Okay I'm doing something wrong here in my calculations. Numbers have never been my forte
Edit#2: Yep. Now it looks normal again. Accidentally calculated for a 5cc dome piston. Getting 10.35 now
Old Nov 2, 2016 | 02:49 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You are....somewhere.......look at my pic that i posted and compare.
Jebby
Old Nov 2, 2016 | 03:37 PM
NewbVetteGuy
That's better; I get 10.37 for static CR for him at sea level using the calculator here: https://www.jeepstrokers.com/forum/calculator/ I estimated a deck clearance as close as 0.015 to get 10.35; if the deck height is actually 0.025" then it's down to 10.12:1.
(Don't forget that the bore of most of the gaskets is actually 4.1" -I believe to support 0.060" overbores.)
Adam
Old Nov 2, 2016 | 03:42 PM
427Hotrod's Avatar
427Hotrod
Really need to measure deck height. As mentioned, many aftermarket replacement pistons will put the deck height pretty low.
JIM
Old Nov 2, 2016 | 04:32 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Jebby
How are you measuring deck height ?
To Static Compression Ratio Seems High?
