THM-400 hard shift into reverse
Old Nov 2, 2016 | 02:48 PM
ChuckAz's Avatar
ChuckAz
Default THM-400 hard shift into reverse
Hello,
I am picking up a 73 L48 Auto for my wifes birthday. The motor has been rebuilt once (pretty stock rebuild) and the trans has a "shift kit" in it. Driving down the road it acts like a typical shift kit with very firm positive shifts. The problem I have is that shifting into reverse from park it really slams into gear. No metal on metal noise just a very hard jerk. I know the THM-400 is reliant on good vacuum, over 15inches to operate effectively. My question is could it be a vacuum problem or just the function of the shift kit? My plan is to put the trans back to stock buy replacing the shift kit valve body with a stock one.
I have checked the fluid and it is very clean with no burnt smell of a typical burnt clutch pack.
I am familiar with ford transmissions and 200-700R4 but not these older ones.
Chuck
Old Nov 2, 2016 | 04:39 PM
MelWff's Avatar
MelWff
What is the idle speed, if too high will slam.
Check the rubber bushings on the nose of the rear attaching it to the frame.
Check the motor and transmission mounts.
