Undercoating
Old Oct 31, 2016 | 06:45 PM
Lilmubby's Avatar
Lilmubby
Default Undercoating
Will rubberized undercoating stick to the fiberglass on my 76 . or is there something better to do the underside with
Old Oct 31, 2016 | 06:59 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Assume you're doing it for the sound deadening properties?
If so, I'd go with truck bed liner....
Old Oct 31, 2016 | 07:11 PM
Lilmubby's Avatar
Lilmubby
Well body is off frame.just want to clean and redo before she goes back on.want to do engine compartment in a low gloss black maybe
Old Oct 31, 2016 | 10:49 PM
gbarmore's Avatar
gbarmore
I used U-POL Raptor bedliner on the entire underside of my 80 including the wheel wells and engine bay. I POR-15'd the passenger tray because it's steel. The only thing I would do different, is after spraying the U-POL Raptor, I would have laid down a couple of layers of a spray on rubberized coating. The noise transmitted past the bedliner coating was significant. It's tough as heck, but not a noise reducer. I have eastwood thermocoustic on 99% of my interior, including over the wheel wells and I am sure a rubberized coating would be a much better solution to outside noise.
Old Nov 1, 2016 | 07:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Will rubberized undercoating stick to the fiberglass on my 76...
Yes. You should be finding factory applied sound deadener/undercoating on both sides of the floor pans and the rear compartment.
Old Nov 1, 2016 | 06:05 PM
Lilmubby's Avatar
Lilmubby
Thanks for the info going to do the rubberized coating from Eastwood and gloss black in engine room
To Undercoating
