Yanking the tach cable or not?
Old Nov 3, 2016 | 08:39 AM
SLBelt's Avatar
SLBelt
Default Yanking the tach cable or not?
I need some advice. I'm finishing up a Dakota Digital gauge conversion on my 71. I have an MSD ignition controller with a tach wire that I'll be using to drive the tach input on the DD controller. However, previously the MSD distributor had a cable drive for the tach. Obviously, now I don't need the cable drive but I'm thinking of just leaving it attached to the distributor and the now free end hidden behind the dash. If I remove it, it will leave a good sized opening on the distributor or I would need to find some way to plug the hole. So, I'm thinking of just leaving the cable in place.
Do you guys think that would be a problem?
Old Nov 3, 2016 | 10:48 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I'd remove the cable and find a way to plug it.
You don't want some cable spinning and flopping around under your dash.
Old Nov 3, 2016 | 12:21 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Remove the cross-shaft gear from the tach drive and you might be okay.
Old Nov 3, 2016 | 07:56 PM
flyeri's Avatar
flyeri
Remove it and find a plastic cap to fit over the threaded connection at the tach.
Old Nov 3, 2016 | 10:31 PM
Richard454's Avatar
Richard454
I had a defunct flashlight- as the batteries corroded- the end cap worked almost perfect-
Old Nov 4, 2016 | 08:22 AM
SLBelt's Avatar
SLBelt
Hmmm, I guess I could could a plastic disc to cover the end of the connection and seal it up with liquid electrical tape. A bit bubba-ish but shouldn't that work if I can't find a correct size threaded cap?
Old Nov 4, 2016 | 12:45 PM
OldCarBum's Avatar
OldCarBum
If you are removing the cable, cut off the threaded fitting, epoxy in a small piece of aluminum, paint the fitting and screw it back on the distributor shaft or,
Purchase a thread gauge and determine the thread, and diameter of the connector. Once you have determined what the diameter and thread is you will probably be able to fine a brass fitting at someplace like Ace Hardware or,
You could check on-line at MSD or any other manufacturer who makes conversion kits to see if they have anything to screw onto the shaft or,
Go on-line and research an AN female threaded cap that might have the same diameter and thread pitch.
To Yanking the tach cable or not?
