Headers for a ZZ4
Old Sep 17, 2002 | 03:27 PM
Mystery Machine's Avatar
Mystery Machine
Default Headers for a ZZ4
Anyone know what headers will work with a ZZ4? Jegs says the ONLY ones that will work are Hookers P/N 2134 for $299. Summit says only the Hedman ones with the "D" shaped interface work. HELP! I need them ASAP.
THANKS! :confused:
Old Sep 17, 2002 | 03:31 PM
VetteNut72's Avatar
VetteNut72
Default Re: Headers for a ZZ4 (Mystery Machine)
Hedman
Old Sep 17, 2002 | 03:47 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
My dynomax headers for a C3 vette fit fine. They only cost $215.
Mark B.
Old Sep 17, 2002 | 04:27 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Headers for a ZZ4 (Sigforty)
According to the GM manual that came with my ZZ4 engine, any header port configuration is fine. The header pipes do not need to be the "D" shape to exactly match the exhaust port.
Basically look at it this way. If you are going from a 2" pipe to a 2 1/2" pipe you won't have any major flow problems. However, going from a 2 1/2" outlet to a 2 inch pipe, with no "blend" you are going to have serious issues.
Going from the "D" shaped exit of the exhaust port to a full round pipe will not cause any major issues, and GM even states that in their documents.
The major thing to look for in ZZ4 / C3 headers is that it will A: fit in the C3 and B: work with angle plug heads.
Good luck.
Old Sep 18, 2002 | 07:35 AM
Mystery Machine
Default Re: Headers for a ZZ4 (BSeery)
Do any of you guys know if the Dynomax Cermaic Coated headers will work with the angled plug heads? :confused:
Old Sep 18, 2002 | 10:17 AM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Old Sep 18, 2002 | 10:46 AM
Mystery Machine
Default Re: Headers for a ZZ4 (OHSIXX)
I just got off the phone with Summitt and they claim that the Dynomax (p/n WLK-86008) will fit the ZZ4 with angled plug heads. I ordered them, only $225 for cermaic coated.
Old Sep 18, 2002 | 10:54 AM
Fevre's Avatar
Fevre
:yesnod: Got angled plug Trick Flow Alum heads and only one plug is a pain to remove, #2 I think, and I am not using the short header plugs.
Old Sep 18, 2002 | 05:52 PM
Mystery Machine
OK, I ordered the Dynomax Cermic-coated headers (p/n 86008) and just figured out that they have a 1 5/8 inch primary and the ZZ4 ports are 1 3/4 inch...is that right? How did you get yours to fit? What gaskets did you use? I would cancel the order but I'm an imaptient, instant gratification kind of guy and had them overnight the headers and of course everything already shipped.
[Modified by Mystery Machine, 10:29 AM 9/19/2002]
To Headers for a ZZ4
