LS2 engine help needed
Old Nov 7, 2016 | 03:11 PM
afiterman's Avatar
afiterman
Cruising
Default LS2 engine help needed
I have an LS2 installed in my '72 C3. The LS2 is out of an '05 stock corvette. I'm almost ready to fire this thing up but I have 2 questions for someone about the LS2 intake manifold.
1. In the front of the manifold, right in back of where the throttle body is attached, is an open port and I have no idea where or if this is connected to something. I've seen some images where its blocked off and some images where its connected but I can't tell where and to what. This is a non-emission engine so I'm not concerned about things like EGR and other related equipment. I've attached an image for reference.
2. In back is a brake booster vacuum port which I won't be using since I have a Hydroboost system which gets its pressure from the power steering pump. Could I use this vacuum port to open & close the wiper door? Any thoughts?? Thanks for any help!
Al
Old Nov 8, 2016 | 08:05 AM
Garys 68's Avatar
Garys 68
Front port is either purge solenoid or PCV. No need for the purge, but set up your PCV.
Rear works fine for vacuum operated wiper/headlights.
Old Nov 10, 2016 | 07:26 AM
afiterman's Avatar
afiterman
Cruising
Default Thanks Gary
Very much appreciate your help Gary. Thanks.
Al
Old Nov 10, 2016 | 08:40 AM
71 Vert LS1's Avatar
71 Vert LS1
I typically cut the front port nipple off and then drill and tap for a bolt. Makes it look cleaner than a rubber cap over the top.
Old Nov 10, 2016 | 04:11 PM
mikem350's Avatar
mikem350
Make sure to use a PCV..it only helps!
To LS2 engine help needed
