Engine Temp on HP engine
Old Nov 7, 2016 | 09:26 PM
edusmc1's Avatar
edusmc1
Default Engine Temp on HP engine
I have fresh 383 stroker motor just built and dynoed 438hp/477tq with Quadrajet carb. Sounded grade on Dyno with no spark knock or anything. Install engine in car my 77 vette runs good very strong but when it gets over 180 temp it spark knocks only when secondary's open up and goes above 3900-4000 rpms. When engine is cool no issue at all. It has 041 heads, stock radiator, new clutch fan, stock ram horn mainifolds with true duals.
My question is, is it possible to make it stay cool under 180? If not what may be causing the issue?
34% timing
93 octane fuel with 108 booster
10.041 compression
Cold plugs, had hot plugs but changed
Auto/trans
355 rear
Factory chin molding
Factory fan shroud
160 thermostat
Old Nov 8, 2016 | 04:34 AM
SH-60B's Avatar
SH-60B
Re-visit the timing. If the static is over 12, back that off. If theres not enough room there, look into limiting the mechanical.
Old Nov 8, 2016 | 05:48 AM
cooper9811's Avatar
cooper9811
Timing adjustment may be your only easy and cheap option short of a cam or head change. I think your compression is just a tad high for modern gas and older iron heads (less efficient chamber IMO). I don't know first-hand, but have read that the 041 heads are susceptible to ping with modern gas.
I would try just a couple of degrees and see how it runs.
Old Nov 8, 2016 | 07:18 AM
fishslayer143's Avatar
fishslayer143
what kind of intake manifold are you using?
Old Nov 8, 2016 | 08:02 AM
diehrd's Avatar
diehrd
34 degrees of timing at what RPM ? Check to be sure heater hoses free flow and are not restricted , make sure no air is in system .
Make sure it is full .. and what radiator are you using
Old Nov 8, 2016 | 11:25 AM
REELAV8R's Avatar
REELAV8R
When it was dyno'd it was using headers on the dyno and not the ram horn manifolds I'm guessing?
Corking up the exhaust by going through those ram horns could be creating a problem.
Have you tried using a different hanger or needles on the secondaries to enrichen the mixture?
Are you using CAI or under hood intake air?
Old Nov 8, 2016 | 12:13 PM
gkull's Avatar
gkull
34% timing
10.041 compression
Auto/trans
355 rear
Factory fan shroud
160 thermostat
Since I'm not right in front of the motor, i'd like to ask a few basics.
how did you get 10.041 C/R? What is your neg piston cc, head compressed gasket height, piston to deck, your heads should be 64 cc.
What is your total timing without the vac advance hooked up and what is the max advance with vac hooked up.
You have more than enough octane with just 93 and your temp is low. real performance and thermally efficient motors run in the low 200 degree range.. who ever talked you into 041 heads was not a friend. poor chamber design, pressed in rocker studs, very low flow even with 2.02/1.6 valves installed
Old Nov 8, 2016 | 12:32 PM
REELAV8R's Avatar
REELAV8R
If everything, ran fine, as you say, on the dyno. And now once installed in the car it isn't fine, I would tend to focus on the differences in the dyno environment vs the installed environment.
Has anything else changed since the dyno other than installation in the car?
I would agree with the opinion on the heads, but it is what it is unless more time and $$ are going to be spent to change it.
Old Nov 8, 2016 | 01:58 PM
MelWff's Avatar
MelWff
what manufacturer and part number plug are you running?
The comment above about whether the dyno test was run with headers or the ram horns should be answered.
Old Nov 8, 2016 | 04:09 PM
edusmc1's Avatar
edusmc1
Eld RPM
Old Nov 8, 2016 | 04:13 PM
edusmc1's Avatar
edusmc1
34% at 3000-3500
Old Nov 8, 2016 | 04:16 PM
edusmc1's Avatar
edusmc1
Yes Sir it was on long tube headers, and engine builder told me it mite be the manifolds plus temp because he ran it and never got over 170 with Dyno machine.
Old Nov 8, 2016 | 04:17 PM
edusmc1's Avatar
edusmc1
And I did change the metering rods and still does the same thing
Old Nov 8, 2016 | 04:19 PM
MelWff's Avatar
MelWff
try a different hanger to enrichen, Edelbrock sells them or tighten the secondary air valve by an 1/8 turn
Old Nov 8, 2016 | 04:20 PM
edusmc1's Avatar
edusmc1
Yes sir I am, the only difference is the headers and 15-20 degree temp difference.
Old Nov 8, 2016 | 04:36 PM
edusmc1's Avatar
edusmc1
Heads were port and polished some, blended and 5 way value job. Flow test after work was done and I believe I remember him saying 254 he was able to get them to flow to. Yes 64 cc heads and block was 0 decked and used H beam rods all eagle stuff. Piston were used to ensure no more than 10:1 ratio so no problem using pump fuel. Only spark knocks when secondary's open up and rpms start to climb over the 3900 to 4000 range. Timing is 34 at 300-3500 rpm and mech only but I did try the vaccum advance also but same thing. I've even retart timing back a little at a time back to 30% but same.
I'm thinking after talking to you Gentelmen the headers is what I'm going to have to do! I appreciate you reading my post and helping.
Old Nov 8, 2016 | 04:37 PM
edusmc1's Avatar
edusmc1
He change to colder NGK plug!
To Engine Temp on HP engine
Old Nov 8, 2016 | 04:41 PM
edusmc1's Avatar
edusmc1
Yes Sir I will try that tomorrow. Thanks a lot for the much need information.
Old Nov 8, 2016 | 05:12 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Summit painted steel headers are dirt cheap; FlowTech (Holley) coated can be had for $319 @ Advanced Auto with coupon. Headers will get you more torque, more hp, and 2 mpg better fuel economy.
Does your C3 have a cold air intake? With your CR on iron heads, you'll probably want a CAI of some kind. Per David Vizard each 8 degrees intake temperature drop will gain you the equivalent of 1 octane detonation resistance. -You'll get more power and more detonation resistance.
You could also retard your cam timing by a couple of degrees to delay your intake close event, which would reduce your dynamic compression ratio / cylinder pressure. You've got plenty of torque so you might as well trade some of it for more HP on the top-end and more detonation resistance.
Adam
Old Nov 8, 2016 | 07:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
Tune was probably optimized to be used with headers putting in a colder plug lost me power...every motor has different needs though.
If it were me Id get an 02 sensor (check AEM at summit for example) in your collector and see what the car is doing;h opefully you can tune around it id think you could
Or if you dont mind the funds get a better radiator/fan combo and bring your running and air inlet temps down.
If you got a cool stat get a better fan (flame suit on)and put the clutch deal off to the side I hate those things
Not saying that is THE solution but you wont regret it for sure. Bigger motor/power means more heat needs more cooling capacity.
Sounds like youre happy with overall power shame someone talked you into dumping all that money into old iron heads.
Keep us posted
