Vert top installation help?
Old Sep 17, 2002 | 05:23 PM
Steve Adkins's Avatar
Steve Adkins
Default Vert top installation help?
Can someone help me out with some instructions on vert top installation? I bought a new top for my 69 and going to attempt to install it myself and don't have the first clue where to start. Can someone help me out please?
Thanks in advance! :cheers:
Old Sep 17, 2002 | 05:51 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Vert top installation help? (Steve Adkins)
Buy the Al Knoch video. It goes through step by step. Did my 69 top a few winters ago. You start by carefully removing the old top, measuring the distances between the bows. Then, you remove the rear bow and install that part first. Then re-attach the bow....measure to the upper attachment for the rear window...staple...etc. The video gives you a step by step. DO NOT try to staple with a hand stapler....buy or rent an electric or pneumatic stapler. Also, you might have to replace some or all of the tack strips. Also....once the old top is off...it's a good time to repaint the bows, etc. This is the kind of project that mushrooms....NOT a project to be done in one afternoon. Chuck
Old Sep 17, 2002 | 05:54 PM
Wrencher's Avatar
Wrencher
Steve check the archives for post on this and use the Ecklers video if you can. It takes 2 persons to do it right, and new rubber at both ends. Also, be sure there is no rust on the front header piece where the tack strip goes. Best thing would be to take it apart in one session, carefully making notes, then get any parts you need. Also you could re-finish the frame, then get help and put it back together. You definitely need a pro quality stapler and good contact adhesive. Some of the adhesive is not rated for high temps.
I did mine first try on my '69 daily driver, although the rear rubber still isn't right. Good luck!
Hans
Old Sep 17, 2002 | 05:58 PM
Wrencher's Avatar
Wrencher
Default Re: Vert top installation help? (Chuck Gongloff)
Chuck, is that the same video that Ecklers sells? I used an Al Knoch top, but no video...
Hans
Old Sep 17, 2002 | 06:08 PM
Tom73's Avatar
Tom73
I used the Ecklers Video and the Factory Service Manual. Between the two I was able to survive. Next time, it goes to a pro to be done.
tom...
Old Sep 17, 2002 | 06:11 PM
Alwyn678's Avatar
Alwyn678
Default Re: Vert top installation help? (Tom73)
tom...
Alwyn678's Avatar
Alwyn678
Default Re: Vert top installation help? (Wrencher)
Hans
Do you have to buy the rubber seperately????????
Old Sep 17, 2002 | 06:15 PM
Chuck Gongloff
I swear we had an Al Knoch video. It wasn't mine. Belonged to a friend who helped me do my top. I'm sure any video would show the proper assembly sequence. Trying to explain how to put the top on over the internet is like trying to tell somebody how to tie a necktie over the telephone. :) Chuck
Old Sep 17, 2002 | 06:31 PM
Wrencher's Avatar
Wrencher
Default Re: Vert top installation help? (Alwyn678)
Yes. the rubber does not come with the top...
Hans
Old Sep 17, 2002 | 10:11 PM
Steve Adkins
Thanks for the help guys. For those of you who have done this, is it worth saving $200 to do it your self?
Old Sep 18, 2002 | 02:23 AM
R1234's Avatar
R1234
Chuck, does the video give some bow measurements? In my case I'm starting from scratch with a completely bare frame. The frame has been sandblasted, primered and painted a satin black.
Thanks!
Old Sep 18, 2002 | 06:10 AM
Steve Adkins
Default Re: Vert top installation help? (68rdstr)
Thanks!
That's what I am doing starting from scratch. I was hoping for some instructions, something like the tech tips.
To Vert top installation help?
