Advice on a aluminum radiator for a 69' Corvette
Recently pulled the original aluminum radiator from my 69' small block Corvette. Doesn't look like this one will be repairable although was running prior to removal. Any advice on a suitable aluminum replacement? I've seen someone is reproducing these but I'm not concerned with originality. Also have seen catalogs with the be cool aluminum radiators. Currently have a non original 350 that I'm planning on converting to a 383 to give an idea. Any recommendations are appreciated!
Received 2,878 Likes
Hi b,
Dewitts make some very nice aluminum radiators.
Besides manufacturing a reproduction for your original they also make some replacements that might interest you since you're considering some engine work.
Regards,
Alan
Regards,
Alan
Received 3,043 Likes
St. Jude Donor '05
No way id reuse that go aftermarket
Former Vendor
I fought overheating issues with my 79 for years and the radiator finally decided for me when it sprung a leak. DeWitt black painted aluminum looks like the original and absolutely cured the overheating.
Dead of summer 95+ degrees, A/C going, idling for extended periods, temp never goes above 190*. Much better than cheap Chinese crap for just a little bit more money.
Former Vendor
Then the next level would be to add the electric fan kit to the above
4149063M
Both of these are located on the lower portion of this page
http://www.dewitts.com/collections/c...minum-radiator
